Guage Connections
Guage Connections
My truck has a set of aftermarket gauges and I want to move back to the ones in the instrument panel. I pulled the panel- painted it, got a new lens and am ready to re-install. I know the wires for the ammeter are hanging in the back disconnected. How do they connect to the ammeter gauge? How does the temp gauge connect? The oil pressure? The aftermarket has its own setup for the temp, oil and voltage. Any help would be appreciated. The speedo and the fuel work fine.
Shawn
72 F100 2WD
72 F100 2WD
re: Guage Connections
I reviewes the schematic. It is how they physically attach that has be baffled.
Shawn
72 F100 2WD
72 F100 2WD
Your '72 should have a circuit board on the back of the instrument panel, so if wires were cut it was done before the panel's main connector. You'll have to follow the wires back from that main panel connector and see where they were snipped.
