Best junkyard leaf springs for my setup?
67-7THREE
Post by 67-7THREE »
im building a trail rig and want know know what "junkyard" leafs i can use. i want good flex and be able to support a 1000lb diesel motor in the front.
as of now, i have 7" shackles in front, custom drop front hanger (about 3") and shackle is gonna get moved forward alittle and layed out
rear has ruffstuff shackle flip with layed out 7" shackles and no blocks
running 37's with 3" body leaf and i would like to remove that if i can
67 F250 Highboy, 6.9L IDI, ZF5, Sterling
67 F100 390, 4 speed, short bed 2wd, sold
67 F100, Highboy conversion, HP disk dana 44, Sterling 10.25, 7.3L Powerstroke, 37", sold
67 F250 Highboy, sold
fordguy_78
Re: Best junkyard leaf springs for my setup?
Post by fordguy_78 »
bronco/f150 80-96 rear leafs, and They will hold a 7.3
http://www.youtube.com/watch?v=UqeFMvLD ... ature=plcp
Phill
78 Mustang
67 F250ish
2010 F250 Harley Davidson
fordguy_78
Like what was said on pirate the f250 rears might not be that bad mine was a mix of f250 main with f150/bronco/f250 mixed for my disiered lift/ flexeness. If i would have kept the leaf setup I was thinking about trying a f350 main out of an obs truck and mixing and matching. And they do die over time, and a big one get the front shock towers out of an mid 80's to 96 so you can use a eyelet stile shock.
to show they do die with lots of flex this is over a couple year progression.
Every inch of a 14" travel shock
and not exactly 67-72 f250 chassis but they are 37 and it is a 67 with those leafs with a 460
Phill
78 Mustang
67 F250ish
CrypticRacer13
Post by CrypticRacer13 »
Whats the length of the OBS rear springs? Eye to eye? Or are you still running the highboy main leaf?
-Mike-
ECV 1849
Build>http://fordification.com/forum/viewtopi ... 22&t=68225
69' F250 Highboy 390ci.,NP435,Dana 24,HPD44,D60
67' Dodge Coronet R/T 440ci.4speed,D60, all numbers correct
72' Dodge Dart 440ci.727,D60,10ptcage street strip on meth 10.40s
05' Chevy Tahoe LT loaded for the wife an the baby duty
12' Ford Focus Titanium Hatch Back, Gas saver for the work week
