Do autoparts store carry Anything Anymore?
No tech discussion, please
Madman
Postby Madman » Sun Aug 11, 2013 10:57 am
I have been putting some serious work into my Dana 44 as of late, and I really try to purchase parts locally to support my town, but when you can't get Dana 44 axle seals, or even Gear Tooth Marking compound, you have to ask WTF? THEY DON"T EVEN CARRY PRUSSIAN BLUE? You have got to be joking me! What the hell has happened to this world?
Sorry, but I have to bitch about this one a little.
2017 Ford Raptor
1975 Ford Bronco
elgemcdlf
Re: Do autoparts store carry Anything Anymore?
Postby elgemcdlf » Sun Aug 11, 2013 11:32 am
You are working on a vehicle that is coming up close to 50 yrs old. Parts stores carry what sells. It is simple supply & demand. They should be able to have it for you next day in most cases.
Madman
Postby Madman » Sun Aug 11, 2013 11:42 am
They don't use Prussian blue anymore? A Dana differential is a rarity? I have to disagree with the supply and demand thing. Can't really think of a 4 wheeled vehicle that doesn't use reduction gears of some sort, and Dana's are still used in Jeeps. Don't believe either of these parts fall under the 50 year old rule.
2017 Ford Raptor
1975 Ford Bronco
Steel Clydesdale
Postby Steel Clydesdale » Sun Aug 11, 2013 1:12 pm
Q: Do autoparts stores carry anything anymore?
A: Only what the average joe will buy frequently.
:x ----------- :x ------------- :x
Seems to me the local short list includes cleaning/polishing compounds, filters/lubricants, trinkets/gadgets and a few parts for 90's and up vehicles.
In my area there are quite a few old Fords on the road, so they carry carb kits and tuneup parts....but mainly, when I need serious repair parts, it's: "We don't have one in stock, but we can order it for you." Turnaround usually is at least a couple of days to a week.
If they made video games that teach car/truck repair, maybe the situation would be different. :roll:
Madman
Postby Madman » Sun Aug 11, 2013 1:47 pm
Steel Clydesdale wrote:Q: Do autoparts stores carry anything anymore?
:yt:
2017 Ford Raptor
1975 Ford Bronco
Subzero
Postby Subzero » Sun Aug 11, 2013 2:06 pm
Same where I live. The stores do have tune up stuff but aside from that for our old trucks there's not much else. It took five days for my K&N air filter to come in. I was surprised they didn't have one at that store let alone all the stores in the whole area :? .
1972 F100 Sport Custom-2WD, Aqua Blue and Wimbleton White, LWB, 302 V8 and C4 trans, P/S, P/B - under construction
Gone but not forgotten: 1968 F100 Ranger- 2WD, LWB, original rebuilt 360 V8, Autolite 2bbl carb, C6 Trans, Hedman Headers, Powermaster Racing Starter, H-Pipe and Glasspacks, P/S, P/B, A/C
elgemcdlf
Postby elgemcdlf » Sun Aug 11, 2013 3:57 pm
Madman wrote:They don't use Prussian blue anymore? A Dana differential is a rarity? I have to disagree with the supply and demand thing. Can't really think of a 4 wheeled vehicle that doesn't use reduction gears of some sort, and Dana's are still used in Jeeps. Don't believe either of these parts fall under the 50 year old rule.
I am not going to get into any pissing match on the subject. Real life is axles are almost never touched in the lifetime of a vehicle. Simply not parts any company would stock unless a specialty company dealing in axles. Which by the way is where I would be looking. As to stain that would be best found in any machine shop supply. Any machine shop should be able to tell you where they get theirs. Dana went belly up in '07. That didn't help matters. Do a search on the net. There are a couple companies out there that specialize in Dana axles (parts). I helped a guy find parts he needed for a front axle some time back. Even then the companies I spoke with said some parts are simply no longer available.
Steel Clydesdale
Postby Steel Clydesdale » Sun Aug 11, 2013 4:14 pm
Hey, Madman:
Here's one source for Dana44 parts--http://www.currieenterprises.com/cestore/alldana44.aspx
And another--http://www.drivetrainspecialists.com/
I have no personal experience with Currie or DTS but hey, it's a start, right?
Good luck!
edited to add DTS
Madman
Postby Madman » Sun Aug 11, 2013 5:08 pm
Steel Clydesdale wrote:Hey, Madman:
Good luck!
edited to add DTS
Thanks...I have tons of sources for parts, just trying to buy local to support local.......
2017 Ford Raptor
1975 Ford Bronco
Steel Clydesdale
Postby Steel Clydesdale » Sun Aug 11, 2013 5:16 pm
:oops:
I hear ya about buying local.
Unfortunately, sometimes it's not possible/practical.
68 Ford Stepside
Postby 68 Ford Stepside » Sun Aug 11, 2013 5:22 pm
That's why LMC & Dennis Carpenter do so well. They sell parts you can't get anywhere else these days.My local three parts houses let me down a week ago. None of them stock a vented gas cap for a '68 F100.It's a sign of changed times. :(
"Have A Great Ford Day"
Madman
Postby Madman » Sun Aug 11, 2013 10:58 pm
68 Ford Stepside wrote:That's why LMC & Dennis Carpenter do so well. They sell parts you can't get anywhere else these days.My local three parts houses let me down a week ago. None of them stock a vented gas cap for a '68 F100.It's a sign of changed times. :(
True dat, in gangsta Colorado Speak! :)
2017 Ford Raptor
1975 Ford Bronco
FordTrucks247365
Postby FordTrucks247365 » Mon Aug 12, 2013 2:05 pm
I was feeling the same way out here in the woods until I went to visit my mother in New Orleans. I started going to the local O'reilly's by her and learned that I was now shopping at a main supply hub. It felt good that they had anything I wanted for my truck in stock. Perhaps try to find a main hub near you. :D
Whateverman
Postby Whateverman » Mon Aug 12, 2013 2:30 pm
quick answer: no.
and sadly (around here at least )after you've waited a week (minimum) for the parts either the price has gone up for some reason the parts guy has dreamed up and/or it is the completely wrong piece (even though you gave them the correct part numbers because you didn't want to play the 'its too old its not in my computer " game)
- still got my first first car 20+yrs later : 69 f100 sorta kinda pretending its a Mercury M100 w/a 70 f350 sport custom cab (factory buckets) 67 grille with 69 ranger cooneyes 68 merc box and hood,some supercool fiberglass fenders i scored way back when, 76 f150 disc brake frontend..currently running a 90 5.0HO 4bbl/c4 auto & 3.50 posi...originally a 360/c6 f100 Ranger with dealer added towpack (incl. kelsey hays trailer brake),boxside toolbox,behind the seat stowage & belly tank...only original parts left on 'er are the frame,rear end,rear springs,and rear bumper...
Donnie
Postby Donnie » Tue Aug 13, 2013 7:13 pm
Prussian Blue, you should be able to source from a good NAPA store...Drive Train Specialitie's or Randy's Ring & Pinion are both good supplier's of hard parts.............Donnie
Return to “General Discussion”
Who is online
Users browsing this forum: Ford-f100-1972
