Here's old buckwheat
This is the 64.. I found it at the local scrap yard, paid 400$ fixed the wiring there and drove it 15 miles home!
Got the clip off buckwheat
Then the cab
Thanks! I never imagined it would so smooth..sargentrs wrote:That's a sweet swap! Great work.
Thanks for the interest!Alstoyz wrote:![]()
I may be off a few inches on that tape because i was having to hold it by myself.. but here is a 4-5" difference in the frame. Its why there is a 2-3" gap between the cab and the bed. I also had to cut a 2" notch in the back of the frame to take up some more of the difference... I had to redrill all the holes for the bed but the cab was no problem! I opted to have the gap a bit larger so I can run my large spare tire.. I'm thinking about a sheet metal filler for the passenger side..elgemcdlf wrote:I do not know how you came to identical wheelbase measurements. I had always thought there was a 4" difference between a slick & a dent BUT
1964 F100 1/2-ton SWB - 114"
1978-1979 F100 1/2-ton SWB - 117"
What are your plans for the big gap between the cab & bed?
I stared down that gap for a loooong while before I decided I could live with it.. the tires are actually pretty close to center but the picture makes them look forward.. i believe i would rather have a bit of a gap than not be able to run my spare (its 1" from the cab when mounted).. it is a little big at 35" but I love that look!!elgemcdlf wrote:I had thought about possibly just adding to the bedsides & steps. Another thought even though you have it bolted down is to slide the bed forward just a tad. When you do the lift you plan you could move the bed forward a little bit that would help without really making the wheels/tires look out of place in the fenders. I played with the wheelbase on my truck when I did the suspension installs. Longer rides better so I stretched it just a little at each end. Of course the other obvious option is to cut the frame down or just leave it alone. Been there on that trying to measure alone. Totally understand.
