Used Air Compressor...
Nitekruizer
Post by Nitekruizer »
I've been wanting an air compressor for quite some time. I have the chance to go look at a used one advertised in the local classifieds. It's a 2 hp model with a 12 gallon tank, not "oil less". I am a hobbyist and would like to use it in my garage for everything from pumping up tires to powering a paint spray gun. I've never owned an air compressor before, so, I was wondering what kind of things I should be looking for? Thanks in advance
Re: Used Air Compressor...
If it runs and holds air the only other thing is the regulator and pressure gauge. If you're going to be spraying paint you should get a drier/filter to go between the compressor and your gun.
Mancar1
Post by Mancar1 »
Good advice :yt:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
stephen44
Post by stephen44 »
rather than HP - you need to look at the CFM rating - this is the amount of air it can produce - most hvlp spray guns need between 8 an 15 at 30 psi - power tools need 10+ at 90psi
also be aware - compressor manufacturers are very optimistic in their ratings and i usually take about 70% of their rating as what I will likely get
thanks
Stephen
Nitekruizer
Thanks guys. Going to look this evening so I'll check all of those.
