Exhaust manifold hardware for a '68 w/390 ?
Senorpablo
Postby Senorpablo » Sun Mar 24, 2013 1:23 am
I'm fixing an exhaust leak and I'd like to replace the rusty manifold hardware while I'm at it. I'd like to maintain the stock heatshield but it doesn't have to be concours correct. At the same time, I'm not interested in a fancy 12-point ARP set.
Does anyone know of a kit, or what lengths the bolts should be? I believe there are two studs on the passenger side for the pre-heat tube.
Truck is in the shop, so I can't check it out myself.
Thanks!
Senorpablo
Re: Exhaust manifold hardware for a '68 w/390 ?
Postby Senorpablo » Wed Apr 10, 2013 10:01 pm
So, I'll answer my own question know that I have the information:
The original hardware seems to be:
qty 14x) bolts 3/8-16 x 1.25"
qty 2x) hex collar studs 1.25" x 3/8-16 x .6" -- for mounting the air intake pre-heat shield
The original hardware was ramp-lok bolts which have a special anti-slip design with integral washer.
Interestingly, the Ramp-lok bolts--and many other original style bolts for our trucks and other classics--are available from:
AMK Products
Bolts:
Kit# F-537
http://www.amkproducts.com/Ford_Fastener_Kits.asp
Studs:
B-12474 - correct style but needs to be cut to length.
http://www.amkproducts.com/bulk2.asp?code=7420&title=Studs+-+Hex+Collar
Corkwheats
Postby Corkwheats » Fri Apr 12, 2013 8:19 pm
Thanks for posting that! I have an exhaust leak, as well, on my 71 Truck w/360. I was wondering where to get the right kind of bolts. Great find on that web site - I've bookmarked it, and will plan on getting my new bolts from them.
For the gasket, I bought the Fel Pro gasket w/heat shield.
This is the next big thing I have to do on this truck - it will be a challenge, but I think it's going to work out great. Good luck to you, too.
Bob
71 Ranger XLT LB 2WD
Tilt Steering, West Coast Mirrors
390, 9.5-1 C.R., Holley 600, D2 Heads, C-6
Custom Grind Oregon Cam
Flotech Headers, 2.5" Duals w/H-Pipe
Senorpablo
Postby Senorpablo » Sat Apr 13, 2013 12:59 am
Corkwheats wrote:Thanks for posting that! I have an exhaust leak, as well, on my 71 Truck w/360. I was wondering where to get the right kind of bolts. Great find on that web site - I've bookmarked it, and will plan on getting my new bolts from them.
Bob
Good luck with your leak.
Hopefully your's isn't as involved as mine was. On my truck, both the mating surfaces on the manifold and heads had some deep rust pitting. On top of that, all the surfaces had a C-shaped arc to them. Ended up having the heads pulled, machined and refurbished. On the bright side, I have hardened exhaust seats now, new guides, seals, one new valve, etc. so the heads should be in good shape.
Sure is nice to have the leak fixed finally.
Return to “Engine”
Who is online
Users browsing this forum: sargentrs
