Can someone please take LOTS of pictures and show me how your 351W alternators are mounted. I need to see the brackets, and how they are mounted. I made the mistake of taking them off several engines to clean them up and paint them. I just can't figure out which ones go together and how to get them mounted.
Patrick
351 Windsor Alternator Bracket Routing
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
- basketcase0302
Re: 351 Windsor Alternator Bracket Routing
Patrick, there are I believe a couple of different versions of the rear bracket in this photo, (the bracket that mounts to the engine head). But for the most part the front bracket(s) will look like this:
Here's the other version of the rear engine head bracket that you might have:
got a pic of how the bottom pieces actually fit on there? Those are the pieces I have.
Chevrolet
- basketcase0302
Patrick, there is no "bottom piece" AFAIK.mrsnicks on Sun Sep 16, 2012 7:03 am
The rear bracket bolts to the head, and the other two brackets bolt onto the water pump/timing cover bolts.
Unless maybe you have a different type of bracket?
The pieces in the bottom picture. I cant figure out how the triangular piece bolts up.
Chevrolet
- basketcase0302
It's the blue bracket one in the top photo. The two bolt holes on the bracket in the bottom pic bolt onto your water pump. Be advised I'd seen more than one variation, (year or A/C making the water pump different) of our water pumps before that could change this? If it won't seem to line up onto the pump-maybe find your old water pump and compare it.
I had more issues matching up my power steering brackets than anything when I did my build a few years ago. It seems the 302 and 351 brackets are completely different for P.S. on our engines/trucks.
I got it figured out. I'll post pictures tomorrow. Due to the fact that my oil dipstick tube was bent I had the piece that bolts to the head (piece with 4 holes) upside down. So no matter where/how I attempted to mount the triangular piece (3 holes) nothing would line up correctly while holding the top alternator bolt.
Attached are the pictures I found online that helped me figure it out.
Chevrolet
- basketcase0302
I looked for 15 minutes yesterday for the two top images you posted above and couldn't find any...
Glad you got it figured out.
