Electrical tool for adding and removing pins...
sublimer
Post by sublimer »
I'm replacing my turn signal switch...I need a tool to put the wires in the connector. I have no idea what it's called. Link? Thanks!
1968 Ford F-100
240cid (3.9L) Inline 6
3-speed on the Floor
2-tone Blacks & White
Custom Homemade Headliner
Moveable Speakers
averagef250
Re: Electrical tool for adding and removing pins...
Post by averagef250 »
The wires crimp into the individual terminal pins then the pins clip into the connector.
There are tools to remove pins, but I've never seen anything special for crimping terminal pins onto wires. They crimp the same as anything else.
sublimer
Post by sublimer »
averagef250 wrote:The wires crimp into the individual terminal pins then the pins clip into the connector.
Ahh, yes, wire crimps!!!
Now a follow up question...
Which pins should I buy for the turn signal switch?
1968 Ford F-100
Moveable Speakers
averagef250
I would imagine you'll need to deal with a hefty minimum order quantity if you shop around electronics suppliers- Allied, Digikey. Possibly there are other dealers that specialize in these parts in small quantities, anyone else know?
Vendors and manufacturers provide exact dimensions for small electronic parts like these. If you can measure your old ones you can match them up to new ones.
I never personally bought a Bump turn signal switch that came unterminated. If I did I would consider carefully removing the old pins from the old wires and re-crimp/ solder them onto the new wires.
CNM67
Post by CNM67 »
Check out HAPPCONTROLS.com
The iron never lies and 200 pounds is always 200 pounds
71PA_Highboy
Post by 71PA_Highboy »
Delcity.net
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
dirtwrench
Post by dirtwrench »
nevermind. just noticed the date of last post on this.
