400m/351m BIG BLOCK BELL HOUSING FOR SALE
Private parties only. No eBay/Craigslist listings.
broke_okie
Post by broke_okie »
400m/351m BIG BLOCK BELL HOUSING $20.00 OBO
DUECE AND A HALF D-RINGS WITH BRACKETS 20.00 OBO FOR THE PAIR
I HAVE PICS AVAILABLE AT : http://www.fordification.com/galleries/ ... album=1137
J.P.-"Happiness is... not being smart enough to know what to worry about."
** 1971 F100 SWB 4X4 SPORT CUSTOM**
broke_okie
Re: EB MANUAL STEERING BOX/F100 P.S. BOX AND MISC FOR SALE
The bell housing is only for the 460/429 thanks
broke_okie
Still for sale. :woohoo:
broke_okie
Dropped price on F100 box to $60.00
broke_okie
F100 PS BOX SOLD.
broke_okie
Still for sale.
broke_okie
Still for sale.
broke_okie
Re: 460/429 BIG BLOCK BELL HOUSING FOR SALE
STILL FOR SALE.
Hawkrod
Post by Hawkrod »
That bellhousing is for a 351M/400 not a 460. It will bolt on but it is not as deep so you have to add a spacer or the input will push the crank forward and chew up the thrust bearing in the engine ( http://www.460ford.com/forum/archive/in ... 39340.html http://www.460ford.com/forum/archive/in ... 24665.html). There is about a 7/16 inch difference between that and a real 429/460 bell (the real ones have the ribs on the outside!). The issue only applies to the D7TA, D8TA, D9TA and E1TA bellhousings as those were all pretty much the same thing slightly revised. You can use them if you use a smaller clucth and a spacer between the trans and bellhousing. Hawkrod
Real 429/460 bellhousing:
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
broke_okie
Ipulled it off of a 429 out of an LTD
Hawkrod
Post by Hawkrod »
broke_okie wrote:Ipulled it off of a 429 out of an LTD
That may be true but Ford did not build it that way. A 77 and newer LTD (It is a D7T bellhousing so we know it was not made before 77) never came with a 429 so it was obviously an earlier car that they swapped the bellhousing into or a later car that had the whole kit and kaboodle swapped into but that is not important, what is important is that we know for certain that it is a 351M/400 bellhousing and not a 429/460 bellhousing and that is all that is really important. We certainly would not want one of our friends here to buy it not knowing of teh potential issues or worse buy it and tear up an otherwise good engine. I am sure everybody here wants to make sure that we always try and help to prevent potentially bad situations. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
crazyhorse
Post by crazyhorse »
Thank you Mr Hawkrod,for looking out for us.
It would be awful to ruin a good motor.
Mr Broke-Okie, good luck selling it .
broke_okie
Re: 400m/351m BIG BLOCK BELL HOUSING FOR SALE
Still for sale.Thanks for the info.
broke_okie
Still for sale.
broke_okie
Still for sale. :)
