68 crew cab project
tybob81
68 crew cab project
Postby tybob81 » Wed Sep 28, 2011 3:06 pm
Just brought home my 68 F600 crew cab and now starts the long road of my next build.
1968 swb hydroboost w/4 wheel discs, ididit tilt column, p/s, all led lights, Vintage Air and painless wiring. F.A.S.T ez efi 5.0, Built AOD. Addco front & rear sway bars, Custom wood bed floor. Full frame off resto-mod.
1968 Crew cab shorty 393w, M5R2, Vintage Air, 4 link and cv front suspension, hydroboost w/ 4 wheel disc brakes...under construction.
tybob81
Re: 68 F600 crew cab project
Postby tybob81 » Wed Sep 28, 2011 3:14 pm
Im looking for a 149-151" Ford 34" wide frame to put the cab on along with a short bed I have off a 68 and front clip off a 69 and a spare 68 steel grill I'm going to chrome. I will most likely use the 393w out of my other 68 and a Mazda 5 speed.
dieselbronco
Postby dieselbronco » Wed Sep 28, 2011 3:23 pm
Man did u get the running boards off the 600 I need a set bad
tybob81
Postby tybob81 » Wed Sep 28, 2011 3:28 pm
No they are still on the truck I didn't need them.
goldies67
Postby goldies67 » Wed Sep 28, 2011 3:46 pm
cool truck! you definately got your work cut out for you! :thup:
1967 f100 styleside
tybob81
Postby tybob81 » Wed Sep 28, 2011 4:06 pm
Yes I do have my work cut out for me. with this build I'm going to show off my skills and get a little more creative on it. With my green 68 I stayed conservative on the mods done to it because it was a to nice to cut up all that rust free metal.
goldies67
Postby goldies67 » Wed Sep 28, 2011 7:34 pm
it would look badass with a nice lift and big tires! 8)
1967 f100 styleside
Swegner99
Postby Swegner99 » Thu Sep 29, 2011 11:23 am
I cant see pictures :( I love admiring the Crew cabs
1972 F250 Custom LWB
1999 F150 Ext Cab
2001 E350 15 Passenger Van
FoPAR
Postby FoPAR » Thu Sep 29, 2011 12:13 pm
:yt: yeah, same here. :nopix:
"FoPar" because I love Fords and Mopars so just call me FoPar... :D
elgemcdlf
Postby elgemcdlf » Thu Sep 29, 2011 5:44 pm
This image has been moved or deleted. No images for me either.
tybob81
Postby tybob81 » Thu Sep 29, 2011 6:35 pm
Worked on getting it stripped down to take it to the dipper to see what I have to work with.
tybob81
Postby tybob81 » Thu Sep 29, 2011 6:37 pm
I guess I'm going to use a 69 f100 4x4 swb frame and splice in the needed length under the cab.
panski
Postby panski » Fri Sep 30, 2011 8:24 am
You're a brave man tybob81 :thup: After the 'green' one, now this? Can't wait to see the progress.... :fr:
'70 Ford F-100 (Project 95%)
'55 Ford F-100 (Project 50%)
'62 Chevy Impala (Project 0%)
Postby Ranchero50 » Fri Sep 30, 2011 11:43 am
So, if you axe everything between the cowl seam and the seat hump and put little truck stuff on it'll be easier right?
Jamie
Builder of dreams, breaker of hearts. Play nice or go away.
tybob81
Postby tybob81 » Sat Oct 01, 2011 8:25 pm
No I'm going to do it a little different. The big differences is the trans tunnel and cab mounts. The floor pans are the same, just there is a hole in the floor for the F600 column. The most of the rust on the cab is the driver side floor and driver side roof drip rail so putting in a new floor pan will do away with the steering column hole and driver F600 cab mount. I am going to drill out the spot welds for the pass F600 cab mount and replace both mounts with f100-350 cab mounts. The rear will either be cut down and boxed or replaced with a F100-350 rear cab mount. As for the brake pedals and steering column holes and locations it is up in the air what I will do.
Return to “Project Updates”
Who is online
