Combating the effects of Purple Power on aluminum intake
fomocoguy
Re: Combating the effects of Purple Power on aluminum intake
Post by fomocoguy »
sargentrs wrote:I'm following you closely on this one. I have an Edelbrock intake from a parts truck I was expecting to use on my rebuild. It needs cleanup, of course, and I've got a big jug of purple power I keep around for cleaning parts. Whew, that was close! Now I think I'll blast it, wipe it with lacquer thinner and paint it silver. Uhhh...thanks? Sorry about your troubles and good luck with it!
I found out on my last project that Eagle One Mag Wheel cleaner works ABSURDLY well on cast aluminum. I bought a 4 wheeler for my gal and while rebuilding the engine I wanted to clean the cases. They were stained a dull reddish color from southern MO red clay. No purple, yellow, or green cleaner would touch the stuff. I used Eagle One Mag Wheel Cleaner and it made the aluminum look like new with very little effort! It is acidic and smells like rotten eggs while it works, but I'm telling you it cleans cast metals like crazy. You have to rinse it well and in short order so you don't damage the metal and if you use it on polished aluminum it will dull it. It will also eat paint so you have to be careful with it. Any guy that accidentally uses this stuff on polished wheels would be really pissed afterward. Anyway their general tire and wheel stuff won't do it; it has to be the Mag wheel cleaner.
evan_flatt69, this will almost without a doubt work for you but be very careful of the painted parts around it...
Here's a good before and after shot
Joe
1971 F100 flareside 8ft
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
evan_flatt69
Post by evan_flatt69 »
If I decide to try to take off the intake and try to clean it my self what kind of tools or replacement parts will I need and should I expect to run into any major bumps in the road?
Here are some pics of the damage:
Right about now I'm wishing my truck looked about as good as my mom's Jeep does
1969 F-100 Short Bed Custom Cab 390
1985 BMW 635CSi
BobbyFord
Post by BobbyFord »
I went to Lowe's and bought some degreaser called Red Max. I used it to clean my C6 trans case, it didn't stain or screw up the aluminum but it worked well.
Here's a before/after
Before
After
F100builder
Post by F100builder »
BobbyFord wrote:I went to Lowe's and bought some degreaser called Red Max. I used it to clean my C6 trans case, it didn't stain or screw up the aluminum but it worked well.
Red Max huh? I might have to try that stuff on my C6...getting ready to do the very same thing and it's pretty dirty. How much for how much?
Patrick
'56 F100; Must.II IFS, 351W bored & stroked to 395c.i. 470hp/483ft-lbs., AOD, 4-link coilover 9" w/ 3.89's
'69 F100; 390, C6, Dana 60 w/ 4.10's
'70 F100; 'new' and latest project soon to have a built 390/C6 and 3.50 gears
To see more of my F100's: http://www.cardomain.com/id/lowfat56
BobbyFord
Post by BobbyFord »
A gallon is about $10
rjewkes
Post by rjewkes »
wow if it hurt the paint and aluminum, i'm worried about the wiring and hoses and belts it got on.
fuelly.com
Thanks fomoco! I'll try that. You too, Bobby! Evan, what can I say man. That is tragic! I had no clue PP would do that. Keep us posted on your progress and thanks for the warning. :( for you.
F100builder
Cool...thanks!
Patrick
The Purple Power I've bought in recent years wouldn't hardly TOUCH aluminum unless it was left on for several hours. This really surprises me!!
Now, the PP I bought back in the mid-to-late 80's would do a number on aluminum!!
AP5424
Post by AP5424 »
give Alumiprep 33 from Aircraft Spruce a try. It removed the oxides (corrosion) and brightens the aluminum
heres the link: http://www.aircraftspruce.com/catalog/c ... miprep.php
its kinda high priced but well worth it.
AP5424
Post by AP5424 »
also for just general purpose degreasing, simple green and a stiff bristle brush followed by a pressure washer
evan_flatt69
Hopefully when we get the headers installed we'll take the whole engine out and take the carb, intake, and heads off and clean and repaint it.
1985 BMW 635CSi
