Has anyone run the GM alternator on their trucks?
bluef250
re: Has anyone run the GM alternator on their trucks?
Post by bluef250 »
check out this thread
http://fordification.com/forum/viewtopi ... alternator
An alternative is the 3 G alternator
The one wire alternator is discussed here also.
spartman
Post by spartman »
Guess I should have added if they have put one on a 6 cyl engine.
If so was there many mods needed?
bluef250
Post by bluef250 »
Two issues you need to consider. First the wiring, that is pretty much the same from the I6 and V8 from the diagrams. Second is installing the alternator, that will depend on the alternator you plan to install and could involve some trial and error and fabrication of brackets.
spartman
Post by spartman »
Not sure of what the amperage is.
It was one I had taken out of a chevy truck with a 350 and I believe it is the standard size.
I was hoping that I could put it in the stock location with a few if any braket mods.
