Dash pad delete defroster vents!
Re: Dash pad delete defroster vents!
14 bolt holes
supreme1
Post by supreme1 »
14...ouch. probably best to weld and grind and repaint. Unless anyone has a better solution.
jart
Post by jart »
For the front holes, 5/16" stainless hole covers from HD, the big box store, on the bolt isle in the pull out trays. For the top holes, 2" stainless sink hole covers from local plumbing store. Pics won't load, "file too large"
BlueFords
Post by BlueFords »
Here they are. This is what you can do for about $25. Both are stainless. The 2" hole covers are
BlueFords
Post by BlueFords »
Here's the 5/16 for the front holes. You could even paint all of them if you want.
