I searched the server and didn't find the definitive laymen answer that I was looking for, so sorry for the noobie first post.
I am looking for a set of steel wheels for my '72 F250 as I am moving to the East coast and want a dedicated set of rims for snow tires.
What is the bolt pattern I am looking for, I saw these on Craigslist and they looked good but I was thrown by the metric figure on the bolt spacing:
Set of four 8x165 lug pattern, 16.5 inch steel wheels. Tires are NOT road worthy. No bends. more paint than rust, still ugly. Perfectly good wheels. Asking $50.
He referred to them as Dodge wheels, and that they'd fit Chevy's, I understand that the center opening is smaller on Chevy's?
Thanks.
'72 F250 Bolt Pattern
- FLHRC
Re: '72 F250 Bolt Pattern
You probably want to pass on the 16.5's, hard to find tires for.
'72 F100 / 351w, C-6
'74 F100 / 351w, FMX
'04 Roadking Classic
Since I made that post I have been searching for studdable snow tires in a 16.5 to NO avail. Point taken.... how about the bolt pattern though?FLHRC wrote:You probably want to pass on the 16.5's, hard to find tires for.
Yes, that is the correct bolt pattern. It is commonly referred to as 8 on 6.5", but 165mm is the same. The main one to watch out for is the later fords (1999+ that uses the 8 on 170 bolt pattern, as those will not work for you). As far as I know, all 8-lug Dodge wheels and some 8-lug Chevy wheels will fit your truck. Also, all Ford 8-lug wheels 1998 and back will fit your truck. Beware that lots of the Chevy wheels have a smaller center hole that will not want to slide over the hubs on your rear axle. That can be machined or ground out if necessary though because it's not a huge difference.
Thanks for the help.
Anyone in the snowbelt know if good 16 1/2" snow tires with studs are available?
any ford rim up to 1997 for the F250 rim. i dont know if and when dodge and chevy changed thier patterns to metric. but dodge and frod 8 lug interchange up to then and the chevy thing is just watcht he center hole to make sure its large enough.
yeah get the 16 in rims and dont buy the 16.5
