Any advice on using vinyl die?
a26tford
Post by a26tford »
Hi,
I am planning on dying a black dash cap maroon to match the interior. Any secrets?
dwpave
re: Any advice on using vinyl die?
Post by dwpave »
I have dyed a couple parts before. Start of with windex and clean the part very well. After that clean it with vinyl dye prep. This comes in a spray can most of the time. Make sure the part is completly dry. Then apply three coats to the part. give the paint about 5 minutes to dry between coats.
Bobaloo2
Post by Bobaloo2 »
In the past. I have found the number one problem can be from human or automotive oil on the part. Like dw says, clean it, clean it, clean it. I have used 409 or Simple Green with good results also, get it very dry, fog on the first coat, then hit it good. I recommend SEM brand, available at auto paint stores and some auto parts houses, it seems to grab and last.
I have used Dupli-Color and Mar Hyde also many many time in the last 30 years.
Bobaloo2
Bob Mayben
1967 F 100 SWB
1963 Bel Air 409
a26tford
Post by a26tford »
Thanks guys.
