Trailer brake controller
68F250
re: Trailer brake controller
Post by 68F250 »
Would it be possible to post a pic of the horn ring? It looks really cool!
Barry
willowbilly3
Post by willowbilly3 »
Sure. Sorry it's kind of grubby right now. I need a stiffer spring behind it because it honks irslf if I hit a bump or slam the door. My top horn contact is one I made because I didn't have enough. I used a piece of a brass screw and a ball point pen spring. But it just looks so cool I hate to go back to the small cap.
surubet
Re: re: Trailer brake controller
Post by surubet »
"That's all I got when I found mine. You just need a hose clamp to hold it on and wire, although that handle is too long."
Thanks again for the info willowbilly3. I bought it and it is on its way. I can cut the handle and weld it up custom short(er)!
And thank you OLEYELLERTRUCK for the position of the line attachment. Now all I will have to do is locate a couple more pieces.
1970 Ranger XLT F250 Camper Special, 2X4, 360, Factory A/C, 2 tone in greens.
Freightrain
Post by Freightrain »
I wonder if a Tbird or Galaxie horn ring would fit?? Have to pull mine off and compare with my galaxie.
I know I had to UNHOOK my horn since the spring is so weak that a good bump would sound the horn!! AUGH! I have since constructed a switch to make it like my Mack truck(hangs above window). It's a chain pull set up.
I would like to find a NON horn ring style horn center for mine. Guess it doesn't really matter since it's not hooked up...but I always hated horn rings!!!! (stylish as they are...they are a pain if you try to steer too quick...you always hit them! )
Bump'n along.
68F250
Post by 68F250 »
Freightrain, a horn button shouldn't be that hard to find.
Willowbilly3, Thanks! That is the coolest looking horn ring center I've seen!!! :rock:
Barry
willowbilly3
For the record, the Warner trailer brake has no connection to the foor brake, it is just a manual lever and you always have to pull it to apply brakes.
Freightrain, my horn honks when I hit bumps or slam the door too hard, kind of annoying. I have got used to the inconvenience. And normally I don't put up with stuff just for looks, but since the horn ring was a gracious gift and it does look right smart, I decided to get used to it.
heep70
Post by heep70 »
That horn ring does look nice on there. 8) I want it back :wink:
You should put a strobing light behind it. :lol: :lol: :lol: Just kidding
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
willowbilly3
Yeah, the white steering wheel and the delux horn ring really sets off the cockpit. But my rattlecan paint is wearing off and the whell is always glack from my grubby mitts. I have a light brown pleather wrap I am thinking about putting on.
surubet
Post by surubet »
willowbilly3 wrote:For the record, the Warner trailer brake has no connection to the foor brake, it is just a manual lever and you always have to pull it to apply brakes.
That's even better! Two wire hookup and I'm ready to tow ... and brake. I could have gotten the wife to build one (electronics degree) but I wouldn't have gotten the nifty deco look!
surubet
Post by surubet »
Controller arrived today! It is clean inside and the test meter says it is working across the board! It even came with a hose clamp to lash it to the column ... Thanks once again willowbilly3!
willowbilly3
Great!! It's funny that so many people do not have trailer brakes. They are a $100 option on the light duty tandems and most people don't pay the extra. I have had lots of men surpeised to see my slide the tires. "You have trailer brakes on that old truck?"
Darn glad I did coming off the mountains down into Denver with the 96 F-150 on the trailer.
