Rocker Arm Adjustment
jmorgan_68
Postby jmorgan_68 » Sat Jul 17, 2010 3:17 pm
I got the newly rebuilt 302 put into my 68 swb but something doesn't sound quite right. I tightened the rocker arms until they were tight against the valves and then 1/2 turn more. Any ideas or tricks to adjusting them?
cdeal28078
Re: Rocker Arm Adjustment
Postby cdeal28078 » Sat Jul 17, 2010 4:32 pm
Are you sure you have adjustable rocker arms? What year 302 is it? Tight against the valves and a 1/2 turn more? I don't understand what you did yet. What year 302 did you get rebuilt? Can you post a picture of your rocker arms? That would help a lot
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
Postby 70_F100 » Sat Jul 17, 2010 4:48 pm
cdeal28078 wrote:Are you sure you have adjustable rocker arms? What year 302 is it? Tight against the valves and a 1/2 turn more? I don't understand what you did yet. What year 302 did you get rebuilt? Can you post a picture of your rocker arms? That would help a lot
clint
:yt:
If you DO have adjustable rockers, did you make sure the lifters were pumped up fully? Did you rotate the engine so that each of the lifters was on the bottom side of the cam lobe before adjusting?
If you have adjustable rockers, the "zero lash plus 1/2 turn" will work. I've always just tightened them an extra 1/4 turn on SBF engines.
Back in '74, I was working for a GMC dealer, and we had a TON of top-end failures on 454's. Through some research, we found that the rockers on those required a full turn past zero lash to center the plunger in the bore to provide the proper lubrication through the push rod and rocker arms.
jmorgan_68
Postby jmorgan_68 » Sat Jul 17, 2010 6:20 pm
The heads are pre-70 289 on a 77 302 block. The rocker arms aren't adjustable
cdeal28078
Postby cdeal28078 » Sun Jul 18, 2010 3:51 pm
Some 289's did have adjustable rockers. Does it have slotted holes where the pushrods inter the heads?
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
cdeal28078
Postby cdeal28078 » Sun Jul 18, 2010 3:54 pm
jmorgan_68 wrote:The heads are pre-70 289 on a 77 302 block. The rocker arms aren't adjustable
I am confused just a bit. YOu know they are not adjustable right? Did you torque them down or try and adjust them. The positive stop type heads all you do is torque them down to about 25ft lbs. There is supposedly a way in the books that has you turn the engine with the cam timing to keep the valves on the back of the cam lobe while you tighten them but I have never done that
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
Postby 70_F100 » Mon Jul 19, 2010 7:12 am
But what you did is essentially "adjusting" them. :doh:
And if they aren't adjustable, why are you asking about adjusting them? :hmm: :hmm:
jmorgan_68
Postby jmorgan_68 » Mon Jul 19, 2010 4:02 pm
Maybe i should reword my question since the rocker arms are not "adjustable". "Installation" may be more appropriate, when i installed the rocker arms i tightened them down against the valves and then went 1/2 turn more. I have ran the engine but not for very long maybe 5 to 10 minutes and there seems to be some rattle in the rocker arms so i don't think something is right.
cdeal28078
Postby cdeal28078 » Mon Jul 19, 2010 6:25 pm
jmorgan_68 wrote:Maybe i should reword my question since the rocker arms are not "adjustable". "Installation" may be more appropriate, when i installed the rocker arms i tightened them down against the valves and then went 1/2 turn more. I have ran the engine but not for very long maybe 5 to 10 minutes and there seems to be some rattle in the rocker arms so i don't think something is right.
That is pretty much adjusting them to a point. I bet you have had chevies most of your life. No insult intended.
On a Ford Positive stop rocker stud all you do is tighten them down and torque them to about 25 FT Ft. Forget about them touching the valve or tightening them down until they touch the valve. Just torque them down to 25 FTLBS.
The rocker arm studs have a large area that you tighten the rocker arms down to. The valves never come into the equation at all. Just torque the rocker arm nuts down to and I THINK it is 25ftlbs. Can somebody else verify that?
Bet honest money your valves are too loose.
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
Postby 70_F100 » Mon Jul 19, 2010 6:33 pm
clint
:yt:
Since you've had it running and the lifters are pumped up, just make sure to turn the engine over so that the valves are fully closed.
That way, there's no chance of a valve hitting a piston or the valve spring retainers hitting the valve guides.
JMcTurnan
Postby JMcTurnan » Mon Jul 19, 2010 6:38 pm
Most 302 you just torque down, in fact every single one i've seen with stock heads you torqued down. 35 ft/lbs i believe is what it was.
jmorgan_68
Postby jmorgan_68 » Mon Jul 19, 2010 7:02 pm
Clint- I have never owned a chevy, we bleed ford blue at my house between me and my dad we own 10 fords. Im 19 years old this is the first truck i have completely rebuilt, I have torn down sanded,painted, and disassembled and reassembled the engine by myself. I wasn't sure if the rocker arms should be torqued down or set some other way, I couldn't find torque specs for them in any of the books i have. I appreciate your advice that is exactly the information that i was needing. Thank you
Return to “Engine”
Who is online
