My 69 F100 Ranger
fire truck
Re: My 69 F100 Ranger
Post by fire truck »
Nice truck man! I really like that color combo.
67 ford f100s rule
Post by 67 ford f100s rule »
TX69F100 wrote:
jnash40 wrote:very nice finally got my welder shipped to me so now i can finish my bump YES
Thanks! That's exciting. I look forward to seeing your progress.
67 ford f100s rule wrote:listen to that 390 rumble. You gotta love an fe. I hope to find one for my 70 eventually
Yes sir! What are you looking for, specifically?
I want a 390 and a 4 speed eventually. My 70 will be the puller for the 67.
Jeff Penland
70 Ford F100 LWB "Nadine" 302/3 speed with overdrive
If you have to ask you wouldn't understand
"I shall hold the line of right as well as that of glory." English translation of the British Penland coat of arms.
TX69F100
Post by TX69F100 »
jp2005 wrote:Good job on the install! what did you do with your 360?
It's still for sale here:
http://www.fordification.com/forum/view ... 11&t=51720
Brent
1969 F100 Ranger 390/C6 <--- Build thread
HayHauler
Post by HayHauler »
So any updates? Have you taken it to the track yet?
No problem can withstand the assault of sustained thinking. -- Voltaire
TX69F100
Post by TX69F100 »
Updates? Yes.
Track? No.
I'm actually in the middle of doing a cam swap (current cam wiped a lobe, I believe, but I was planning a swap anyway as I have been underwhelmed by the Mutha Thumpr).
I will upoad some photos of the swap as I get time. Work has been pretty busy lately.
Brent
HayHauler
Post by HayHauler »
YIKES! :eek: What cam are you going with
71F100SportCustom
Post by 71F100SportCustom »
Looks awesome..
1971 F-100 Sport Custom
302 3 speed
(converting to automatic)
TX69F100
Post by TX69F100 »
HayHauler wrote:YIKES! :eek: What cam are you going with
Finally decided on a cam, this custom grind hydraulic roller from Barry @ Survival (specs are 280/285 230/236 .556/.556 110):
http://store.survivalmotorsports.com/fe ... -110-.html
I'll post up a few pics of the damaged cam/lifter shortly.
Brent
TX69F100
Post by TX69F100 »
Here are the photos as promised. I apologize for the quality, as I took these using my phone.
Front cover and timing set removed:
One of these is not like the others:
Bad lifter flipped, compared to a good one:
Cam out, screwdriver pointing at flattened lope:
Close-up of damaged lobe:
Brent
sport71
Post by sport71 »
That sucker really wore down. Barry is a good guy. I've done business with him before. He will help you with your needs like he did for me when I put the
4.25 stroker set up. Best of luck brother.
Ruben
Those who do not learn the lessons of history, are doomed to repeat it.
TX69F100
Post by TX69F100 »
Thanks Ruben. How's yours running?
Brent
sport71
Post by sport71 »
TX69F100 wrote:Thanks Ruben. How's yours running?
sorry about the late reply, ive been so busy lately. my truck is great, i take it out every weekend,burn a little rubber here and there and love the attention 8)
TX69F100
Post by TX69F100 »
Have you put it on the dyno or taken it to the track with your current setup?
Brent
Joshpow
Post by Joshpow »
Nice truck. Looking good.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
sport71
Post by sport71 »
No dyno, the track yes. And I had no traction, spun the tires half the track, so I'm not worried about adding more power because it has plenty. :thup: :thup:
