big caddy
No tech discussion, please
warponyxlt
big caddy
Post by warponyxlt »
just got a 67 caddy calias coupe for 350 good shape no dents good chrome decent interior every thing is there only problem is the motor is stuck any one know how to loosen a frozen stuck engine i was thinkin atf or fuel oil. the motor is a 429 does that engine have solid lifters. has any one ever see a sbf in one of those cause that is what i got planned for it if the original mill is junk
if its fixed break it again red white and ford blue the only up hill thats good is the one you are going down
tanusfarms
Re: big caddy
Post by tanusfarms »
my father and grand father always swore by useing coke classic in the cylinders and letting it sit i can't remember how long i think it was either 1 day or 1 week. I personally have never done this as I have never messed with a froze engine but I know I've heard of this method before from others.
Greg
Custom Built and modified F250 highboy, custom dump box, Warn model 8274 winch mounted on the 335 lbs front bumper
Image Image
papabug71
Re: big caddy
Post by papabug71 »
Mix up 50% type F tranny fluid & 50% acetone in a squirt bottle. Pull the plugs & fill each slug up as much as poss. If that dont break it free nothing will :thup:
Buddy of mine had a 68'ish caddy with the 500 in it. Talk about a massive piece of iron.
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
chris72
Re: big caddy
Post by chris72 »
coool! any pic`s?
ezernut9mm
Re: big caddy
Post by ezernut9mm »
yeah, real cool. love the big caddys! i un-froze one with straight diesel in the cylinders and a breakover bar. check the frame for rust at the kick ups behind the front tires. they are famous for that.
i would love to see picks.
Re: big caddy
some one told me diesel fuel in the cylinders might do it.
69FLATBED
Re: big caddy
Post by 69FLATBED »
Diesel fuel is what i've akways used too.
Troy
_________________________
2000 F350 4x4 Crew Cab PSD
1969 F350 Flatbed 360 4spd DRW
!968 F250 4x4 Crew Cab SWB
Love my diesels hope to be gasoline free soon!
Redcap
Re: big caddy
Post by Redcap »
Diesel, ATF and a little Aero Kroil mixed. Works like a charm.
warponyxlt
Re: big caddy
i dont know how to post pics got every thing to do it tho I looked up calias and found ads for stiffy pills tho
Re: big caddy
calais not cialis
warponyxlt
Re: big caddy
it still popped up tho get it
1982 flareside
Re: big caddy
Post by 1982 flareside »
I used pb blaster on a old 65 impala 283 it worked fine.
Jeremy
1971 Ford F250 camper special 360 T18(old model) 4 speed 4.11 gears 2wd with 1969 doghouse soon to be daily driver FRANKENFORD
1982 Ford F150 flareside 300 T18(new model) 4 speed 4.11 gears 4wd Daily driver
Some people say my truck is ugly and all i say is "Beauty is in the eyes of the beholder.
warponyxlt
Re: big caddy
atf and gas mix did the trick took like ten minutes got it to turn and sprayed it all over when i tried the starter there is no plug wires or numbers on the cylinders any one know the cylinder numbering and location of number one on the dist cap. sorry about the off topic subject but the bump still runs and idle hands are the devils work gotta do something fixin cars is my drug. besides there are so many people here that know so much together it is irristible to ask thanks
Re: big caddy
gm went 1 then 3 5 7 on one side of the motor i think then 2 4 6 8 on the other side. thats all i know what year is it? 67 ok. my oldest book goes back to 1975.
tanusfarms
Re: big caddy
the odd side is opposite of fords
Greg
Image Image
