Alternator wiring
- OldRedFord
Alternator wiring
How many wires go to the alternator on a 1972 F100? I only have two that I see.
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
- OldRedFord
Re: Alternator wiring
With full gauges. One of the wires has a rubber boot on it. The boot is orange I think. The other wire just has a round terminal on it to slip over a post.
The wires are laying on the crankshaft pully in the pic.
Tim
it should have a total of 4 wires. orange is the main power wire. to the large stud. black/red would go from the alt to the regulator bolt as for a ground. i have posted pictures of how the wires should go. the colors may vary but they are hooked up correctly. http://www.fordification.com/tech/wirin ... _quick.jpg
and here is another one i took a picture of.
the black one in all of my picturs of the alternators are ground to the regulator bolt. black /red on the diagram. yellow is orange on the diagram i dont know what the other colors match on my pictures. you just have to follow the diagram for your truck i guess.
- OldRedFord
Thanks Fordman for the pics. That helps a lot. Looks like I am just missing the wire between the Alt and the voltage regulator.
Tim
- OldRedFord
Where does the black wire on yours go on the voltage regulator?
The alternator wires are a black/red wire and a orange wire.
Tim
- BobbyFord
Here's the wiring on my '72 gauge type alt:
my black one goes to the botl on the core support that holds the regulator on to the core support. it is a ground wire. just as in bobby's pics. the Black wire with red stripe is the ground wire. it runs from the alternator ground stud to the core support.
- OldRedFord
Thanks a lot for that. Exactly what I need to do. Now I see I have the black plastic splice thing on the wrong terminal.
Tim
