68 390 teardown-update
towtruckerfour
Postby towtruckerfour » Sun Apr 11, 2010 9:34 pm
I tore down the motor today to see what went wrong with it and this is what I found. The rest of the engine seemed ok.
Does anyone by chance have an extra connecting rod they might want to sell and how much?
Last edited by towtruckerfour on Wed Apr 14, 2010 10:49 pm, edited 1 time in total.
Troy
Why is it that the trucks are always the best running vehicles in the family?
Ford means "found on road daily"
70 F100 Custom-352 w/68 Highboy 4x4 frame. My play/project truck
70 F250 Explorer-390/C6 auto. My work truck
04 Mitsubishi montero-family car
Dirty Offio
Re: 68 390 teardown
Postby Dirty Offio » Sun Apr 11, 2010 9:47 pm
Ouch man! I just moved, if I had seen this before I moved I had a set of 390 and a set of 360 rods. Hopefully someone has one to hook you up tho!
When in doubt, hit the gas. It may not be the right answer, but at least it ends the suspense!!
The only substitute for Cubic Inches, is Cubic Money!
1967 F-100 swb "Varmit"
1968 F-250 4dr lwb "Beast"
1976 F-350 drw 460
1977 Club Wagon
1986 F-250 lwb
Dragon
Re: 68 390 teardown
Postby Dragon » Sun Apr 11, 2010 11:13 pm
I have been telling people FE rods don't break. The cap came unbolted on that one. From the 390 to the 428 all the rods are the same length but the weights are not.
Ebay rods for 390 with some other junk
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
71 Service manuals Volumes 1,2,3 and 4 So ask away. :)
My Gallery
Spark test
convincor
Re: 68 390 teardown
Postby convincor » Mon Apr 12, 2010 6:11 am
Think you may be needing a crank for that too....
"Still Plays With Trucks"
towtruckerfour
Re: 68 390 teardown-update
Postby towtruckerfour » Wed Apr 14, 2010 11:04 pm
Hey guys. This is what I found on further teardown and need some help with some questions. Thanks for any help. I haven't rebuilt a motor since high school which was 1988 and I had my dad's help back then.
This is at the bottom of the cylinder. The crank had a couple marks that look not so great either. My questions are:
1. Is the block still usable?
2. If not, I also have a 360 that I'm wondering could I use the block and rebuild it with the parts from the 390 since I thought they were the same block?
3. Can I use the crankshaft from the 360 with the 390 parts?
Thanks again for any help with this.
Troy
Postby fordman » Wed Apr 14, 2010 11:08 pm
i put a 360 cam in my 390. i had no problems. i used the matching liters when i changed the crank. i kept them in order too.
Dragon
Postby Dragon » Wed Apr 14, 2010 11:21 pm
That is minor scuff marks. The 360 rods nope if you want a 390 the piston and rods need to go over along with the 390 crank to the 360 block.
Old Fords Rule
My Gallery
Spark test
towtruckerfour
Postby towtruckerfour » Thu Apr 15, 2010 8:02 am
Thanks guys. I knew I would find some more damage but was hoping the block was not hurt. I saw the scuff marks and did not think they were too bad either. I'm just wondering if the block is still usable with the little chip out of the cylinder wall at the bottom. Otherwise , I will use the 360 block and rebuild it with the 390 parts. I'm hoping the crank is salvageable. The marks are more like dents but are pretty good ones. I'll see if I can get a good picture tonight so you can see the marks.
Troy
James72
Postby James72 » Thu Apr 15, 2010 8:55 am
I would use the 360 block, that one is probably usable but if you have another...
Also, that looks like pitting on the cyl. wall, I'm not sure what would cause that I usually only see that on bearing surfaces or liners
It looks like that rod bolt broke, if both nuts are still on (can't see both in the pic)
I also have a super clean block that has never bean boared but I dought you'ld want to ship it haha
A machine shop will be able to fix up your crank for you too.
'05 Mustang GT
'72 crew 4x4
'07 KTM 450 xcw
2006 F350 CC Diesel 4x4 Lariat
OldRedFord
Postby OldRedFord » Thu Apr 15, 2010 12:21 pm
That might not be pitting at all. Just flakes of junk.
Id like to see what the crank looks like.
Tim
1972 F100 Sport Custom 460/c6/9" rear
1997 F250 XLT CC/SB 7.3 Power Stroke 4x4 (dd)
In chat most nights from 11pm to 1am EST
towtruckerfour
Postby towtruckerfour » Thu Apr 15, 2010 10:34 pm
Here is what the crankshaft looks like. The dents are not as bad as they could have been. Is this usable? The dents are not deep or sharp and I wouldn't think they would affect the bearing as long as everything was cleaned up real good. I can disassemble and reassemble the motor but just am not good with the specs and that stuff. Thanks guys
Troy
BobbyFord
Postby BobbyFord » Thu Apr 15, 2010 10:39 pm
I'd be looking for a crank if it were me.
Postby 70_F100 » Thu Apr 15, 2010 10:46 pm
BobbyFord wrote:I'd be looking for a crank if it were me.
:yt:
That crank is pretty much toast... :doh:
Dragon
Postby Dragon » Thu Apr 15, 2010 11:22 pm
You might save it by going .010 under but it took a beating. I knew that from the rod pics as that crank journal is what hammered that rod cap out straight and mashed the rod end in.
Old Fords Rule
My Gallery
Spark test
Dirty Offio
Postby Dirty Offio » Sun May 16, 2010 1:13 pm
Since you are in Idaho, on the other side of the state are 2 places you might be interested in.
In Shelley or Firth, there is a mechanic/machinist named Oily, he is an FE block guru and has alot of parts.
In Idaho Falls, there is a machine shop, Jerry's Machine, that has a good supply of turned craks on hand. Bought the crank for my 390 there, it is still running 10 years later. Just take your old one to him, then you do not have to worry about a core charge.
1976 F-350 drw 460
1977 Club Wagon
1986 F-250 lwb
Return to “Engine”
Who is online
