390 heads on a 360
1982 flareside
390 heads on a 360
Postby 1982 flareside » Tue Mar 02, 2010 4:55 pm
Would i have any problem with 390 heads on a 360. I know a dodge 318 with 360 heads knock off the compression./
Jeremy
1971 Ford F250 camper special 360 T18(old model) 4 speed 4.11 gears 2wd with 1969 doghouse soon to be daily driver FRANKENFORD
1982 Ford F150 flareside 300 T18(new model) 4 speed 4.11 gears 4wd Daily driver
Some people say my truck is ugly and all i say is "Beauty is in the eyes of the beholder.
DuckRyder
Re: 390 heads on a 360
Postby DuckRyder » Tue Mar 02, 2010 4:59 pm
They are the very same heads.
(So, no you won't have a problem provided you stay within the year, application and port configurations)
1972 F100 Ranger XLT (390/C6/Dana 44 Locker)
1982 flareside
Postby 1982 flareside » Tue Mar 02, 2010 5:45 pm
Somebody told me the 360 was weak on the top end.
Jeremy
convincor
Postby convincor » Tue Mar 02, 2010 5:53 pm
the only difference between a 360 and 390 is crank, rods, and pistons.
oh, and the sticker on the valve cover :wink:
"Still Plays With Trucks"
HOWDY69
Postby HOWDY69 » Tue Mar 02, 2010 8:10 pm
1982 flareside wrote:Somebody told me the 360 was weak on the top end.
360 was/is/are low compression...not quite the same thing.
69 F250, FE Specialties 410, CJ Valves, RPM Intake, Holley 4150,......10 Smiles per gallon
71 Clydesdale in many pieces; 302 roller motor waiting impatiently
Hawkrod
Postby Hawkrod » Tue Mar 02, 2010 8:14 pm
Yes you are correct and to add to that, the low compression has nothing to do with the heads. As already noted, all regular FE engines (352, 390, 410 and even the standard 428) usd the same heads in a given year. That is to say a 67 352 and a 67 428 will both have a C7AE-A heads or a 69 360 and 390 will both have the same C8AE-H heads. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
http://www.supermotors.org/registry/vehicles/index.php?_userID=2829&detail=1
sideoilerfe
Postby sideoilerfe » Wed Mar 03, 2010 12:24 am
"Top end" as in higher RPM HP. 360's are a low RPM torque engine for towing and working hard, like a 300 I6.
1982 flareside wrote:Would i have any problem with 390 heads on a 360. I know a dodge 318 with 360 heads knock off the compression./
Mopars are completely different than FE fords.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
1982 flareside
Postby 1982 flareside » Wed Mar 03, 2010 8:32 am
Mopars are completely different than FE fords.[/quote]
Yeah like oiling to the heads are weird.
Jeremy
CH3NO2
Postby CH3NO2 » Wed Mar 03, 2010 11:02 pm
All engines are different from FE Fords thats why I like them!!
Return to “Engine”
Who is online
