Horn question
tcope
Horn question
Post by tcope »
Is there a good/quick/easy way to test the horn on my truck to make sure they are working? Just hook a wire from the battery to the tab? I tried that, but nothing happened. Does that mean my horn does not work, or am I just being dense? :hmm: :?
heep70
Post by heep70 »
Yep, make sure the horn is grounded and run a wire from the poss post of the batt to the horn tab. If nothing happens, its dead.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
tcope
re: Horn question
Post by tcope »
I'm assuming the horn is grounded by touching the radiator support. Is that correct?
72hiboy4x4
Location: As far away as I can be from Wa state, without crossing the Mississippi
Post by 72hiboy4x4 »
try loosening the horn mount then wiggling it back and forth a little to make sure you have a good ground,then tighten it back up. run the jumper wire to the pos side of the battery and it should work.
just watch your ears! LOL
tcope
re: Horn question
Post by tcope »
Yeah, and your head... That hood latch is a killer! :oops: :eek: :D
Heavenlyfire
Post by Heavenlyfire »
Well i was going to warn you that it will be loud but, lol, sorry.
tcope
re: Horn question
Post by tcope »
Well I didn't hit my head THIS time, but I have done it multiple times while working on the carburetor...
OUCH.... :doh:
tcope
re: Horn question
Post by tcope »
So one more horn question: Can non functioning horns be rebuilt, or is it more effort than it's worth? I'm guessing this is the case, but I thought I'd ask out of curiosity...
oldschoolrods
re: Horn question
Post by oldschoolrods »
if you need a horn i have one laying in the garage that i dont need and i believe is good, if your interested ill check it out.
1969 Ford F250 Custom Cab 360/C6 - currently under de-construction
tcope
re: Horn question
Post by tcope »
I'm not totally sure that the horns are the problem yet, although nothing happened when I connected the wire from the positive post of my battery to the tab on the horn. I might be interested in the one you have, but I think I will mess around with the ones I have first...
8)
NM5K
Post by NM5K »
You will hear the horn relay click if the
horn is bad, but it's actually getting power.
The relay is easy to hear if the horn isn't
blowing..."click-clack"... If you don't hear
the relay clicking, you have a problem
elsewhere. You can double check with a
VOM to test for 12v at the horn terminals.
You probably have a dirty/bad horn contact
button, or bad ground, etc... The contact
button is under the horn cap, which you can
take off by pushing, and twisting, to clear
the plastic tabs. Don't force!!! You will break
the tabs, and have to buy a new plastic part
for about 18 bucks... The button is a little
brass cyl with a wire attached. If it's dirty,
try scraping it clean with a knife blade, emery
cloth, whatever...Don't break the wire...
BTW...Make sure the fuse is ok...
Not sure what the horn shares with...
The relay is near the horn. Horns are a dime
a dozen at any junk pard, or you can buy them
from LMC, etc, etc... Horns don't go bad very
often..It's usually something else. MK
1968 F-250 / 300 six / T-18
Dana 60 - 4.10 Limited Slip
