1967 F-100 project
67nukeford
Re: 1967 F-100 project
Post by 67nukeford »
Had to make some patches in the box floor, that's why I have the one panel I welded these panels from the top and bottom, to make sure they were strong. Had to replace one of the supports along the bottom also.
Pat 1967 F100 4WD
LINK TO PROJECT THREAD
:http://www.fordification.com/forum/view ... &sk=t&sd=a
67nukeford
welds
Pat 1967 F100 4WD
67nukeford
front patch
Pat 1967 F100 4WD
67nukeford
another small one
Pat 1967 F100 4WD
67nukeford
shot the box in epoxy. Flipped it over, and shot the underside in epoxy, black urethane.
Pat 1967 F100 4WD
67nukeford
Oh, then shot 3M undercoat on also.
Pat 1967 F100 4WD
67nukeford
Mounted the 79 power steering box. Had to make a cut out in the crossmember to get to where the nuts would be welded on.
Pat 1967 F100 4WD
67nukeford
Mounted the box, then welded the nuts on the back. Welded the plate back on the crossmember.
Pat 1967 F100 4WD
67nukeford
Had the new doors dipped. I'll have to do some patching in them, and fill the trim holes that I won't be using.
Pat 1967 F100 4WD
67nukeford
Shot them in epoxy, then filled the belt line trim holes, and the holes for the factory mirrors, since I'm using a late model mirror. Also patched the corners.
Pat 1967 F100 4WD
67nukeford
Had to replace the bottom of the inner drivers side door, it was pretty rusted at the bottom.
Pat 1967 F100 4WD
67nukeford
Back to the box sides. I knew I was going to have to replace the flanges, to weld the box sides back on, so, got those made up and attached.
Pat 1967 F100 4WD
67nukeford
clamped and welded
Pat 1967 F100 4WD
67nukeford
The passenger side box corner was in pretty bad shape. I was able to find the NOS corner, and the NOS inner support online.
Pat 1967 F100 4WD
67nukeford
Welded some bracing inside the box before removing the cab corner.
Pat 1967 F100 4WD
