4x4 engine perch differences?
green68250
Post by green68250 »
Are there any differences between the engine perches for a 400 vs. a 390 in a '77 F-250 4x4?
Thanks,
Corbin
Honestly, I really would rather push a Ford than drive a Chevy.
1969 F-100 4x4 Dana 44 w/ disk brakes and power steering conversion 390 c6 np205.
1970 F-250 97k original miles bone stock 390 np435 most original unmolested truck I have ever owned.
2001 F-250, Extra Cab, 4x4, 7.3 Direct Injected Turbo Diesel, Edge Programmer, Flowmaster 4" Turbo back Exhaust, 3" Leveling Kit with 33" Goodyear Wrangler DuraTracs, and has 250,000 miles and counting.
averagef250
Re: 4x4 engine perch differences?
Post by averagef250 »
there weren't 360/390 perches in a 77 f250 4x4. 76 was the last year of the FE. The frame rail hole locations changed from 76-77 for the new 351m/400 and the frame stands are about an inch shorter for the new engines.
If you find a pair of 67-76 FE/300 six frame stands you can put them on the frame in the right spot and about 3 of the 6 holes will bolt up. You will have to drill the other 3 holes on each side.
