someone answer quick please
flatblack
Post by flatblack »
im in a bit of a time crunch so i was wondering what the piston rings should be gapped at on a 390 FE standard bore.
Nitrous is like a hot girl with std's... you know you want to hit it but your afraid of the consequences
Re: someone answer quick please
what do you mean gapped? the oil ring goes on the bottom the other two go in the top two holes.
flatblack
Post by flatblack »
when checking by placing in the cylinder bores
flatblack
Post by flatblack »
nevermind found them on ford FE, top ring .015 to .023, second ring .010 to .020, oil rings .015 to .055 if anyone else needs them for reference
FORD428CJ
Post by FORD428CJ »
Also depends on the pistons you are using! If they are KB pistons then you need to fallow there instructions for there ring end gap! Otherwise you will have some sever problems. If they are OEM type pistons then you have nothing to worry about.....JMHO
Wes Adams FORD428CJ
Built Ford Tuff With Good Ford Stuff
79 F-250 X-Cab 4x4 6.9 Turbo Diesel
64 Falcon X-Ram 428
55 FORD Truck 4-link Rides on air with X-Ram 428
67 Stang 351 C/J
2000 Yamaha V-MAX VMOA#4277
flatblack
Post by flatblack »
the pistons are stock, we are just doing the bottom end on a 390 that only has 40,000 miles on it, no ridge just a hone bearings and rings
