360 fe to a 351w
adam2749
360 fe to a 351w
Post by adam2749 »
I recently purchased a 351 for my 68 f100 short bed. Was wondering the difference in motor mounts and where to buy the right ones...and I have a new ac delco tranny auto overdrive for a small block ford...I was wondering if there is a difference in the transmission cross member and mounts? anyone done this swap before....love to hear what I should watch for. Thanks
fireguywtc
Re: 360 fe to a 351w
Post by fireguywtc »
You can put a thread in the "parts wanted" section of this forum. Good chance someone will have some motor mounts for you. Also remember to check craigslist and ebay because you never know. Not sure about the tranny mount though.
Bill
1970 F-250 4x4 highboy ranger 390 V8, 4spd
2012 F-350 PSD FX4 LWB CC lariat, white
http://www.fordification.com/galleries/ ... hp?uid=602
"If you want to judge a person's true character, give them power."
willowbilly3
Post by willowbilly3 »
You will need the 302 engine towers from a 69-79. Also make sure you have the proper flexplate. A lot of them will bolt on but the balance will be wrong if it isn't the correct one. Expect to move the rear cross member and have a custom driveshaft made or at least the old one modified to fit. Also I suppose you know about the TV cable to the tranny? You must have it and have it adjusted properly or the tranny will fail very quickly.
Lar4t9r
Post by Lar4t9r »
willowbilly3 wrote:...Also I suppose you know about the TV cable to the tranny? You must have it and have it adjusted properly or the tranny will fail very quickly.
What's this? :?
Laurence (Proud owner of 1969 Ford F-100 and 1970 GTO)
ezernut9mm
Post by ezernut9mm »
What's this? :?
kickdown cable or linkage.
Lar4t9r
Post by Lar4t9r »
ezernut9mm wrote:
What's this? :?
OK, Thanks. :thup:
