Starting in Cold Weather
So my truck has trouble starting in cold weather, like I guess the choke isn't warm enough. But after 6-7 times of working at it, it will stay running. I love for my trucks to start on a dime? Any ideas what might help, maybe an electronic ignition?
Re: Starting in Cold Weather
usually i pull my choke all the way out and mash the gas and then it starts up after a few. you just have to go inside and let it warm up a few more minutes . come back out and push the choke most of the way in an it will stay running and you can drive any place. mines a 68. i also have a 67. but i've only drove it once about 10 miles. last summer i think.
Well I put an electric choke on there thats hooked to the alternator, and it wont stay running. It shuts off, which how can it warm up?
Now I could always put a manual, and run it into the dash.
it may be in the electric choke adjustment then. i think about twoo notches toward the back is what i have seen on other trucks. but that will vary some what. im thinking about rich and lean i'm sorry. can anyone else explain the electric choke . i'm not experienced with it.
- SteveC
now this may sound silly but what do you have for a aircleaner???
I had a open elemnent filter on my 67's 352 and when it gets cold up here 15-50 degrees the truck did not want to run worth anything. I put the stock on back on with the heat riser so the carb cold get warm air...and now instead of having to really crank in the cold and having the engine just spit and sputter no matter where i set my manual choke..., the truck starts much better and only have to wait about a mintue or two before i can drive...
just a thought
just a thought
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
- 19674x4
well, you might consider scrounging around junkyards for another electric choke, or you can run a manual one.as of right now, i dont even have a choke. . its on a holley 4412 racing carb. its a bit of a chore to start when it gets below zero but i just give it gas and hold it at about 1000 rpms and it will work its way up to about 1500 or so and then i let it sit and warm up for about 5-10 min and it drives fine.
My Photo Album
- MadMaxetc
It sounds like the electric choke needs adjusted. Holley has good info on this at there website.
I never had any luck with electric chokes, they always shut off to soon. I only run manuals now.
Dan
Project: '63 F-100 LWB / 460 / C6 / 2x4 / Work In Progress!
Daily Driver: '67 F-250 Converted to F-100 LWB / 300 / T-5 / 9" 3.70:1 / 235/75R15 Tires
1/4 mile in 17.64s @ 75mph (it's 4200lbs!!!)
"Work Harder! Millions On Welfare Depend On YOU!!"
FORD Girl
Photobucket Pictures
FORD Girl
Yea, Im seriously thinking about putting a manual on. It will help, plus if someone tries to rob my truck they wont know wtf to do
Do it I just got done doing mine and it works perfectly. Good luck, BillJMcTurnan wrote:Yea, Im seriously thinking about putting a manual on. It will help, plus if someone tries to rob my truck they wont know wtf to do
Proud owner of a '67 F100. 390 cid, Edelbrock performer, Holley 650 vs, hooker headers and a Crane cam. B&M built C-6 and 350 gears in the rear end.
- sideoilerfe
What kind of carb? My Holley electric choke works great. I TAP the gas just enough to feel it engage and turn the key. It fires right up. The Motorcraft on my 72 came off of my 78 LTD station wagon and it worked great in that car but i put it in the 72 and it sucks. My 68 has a manual on the original Autolite and it works great. I pull it out, start it and when it runs about 5 seconds or so, that's when I push it in a little pit and drive it away.
You just need to play with the choke a bit. Your 68 should have a manual choke already.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
- sideoilerfe
From the pic in your signature, you've got a 67 F100. At least the grille and hood emblems are 67.
No, Its just what I want my truck to look like in the end. It's a 68, but looks like it has a 67 grill. Its not my actual truck I wish
- DuckRyder
Fix the electric choke properly.
However, if it is a factory choke it is probably hot air assist as well.
- sideoilerfe
If it is a 68 it should have a manual choke. If it's got a newer carburetor on it with a hot air or electric choke then it should be fixed properly.
