DeVillbis HVLP Gun - Correct tip diameter
bjde0b
Post by bjde0b »
I have the oppurtunity to buy a Devillbis HVLP Finish Line II (Model Number FLG-626-322). I have been trying to research this gun but the only information I can find is on Finish Line III models.
The gun has large tips, which is my biggest concern. Not being a painter I don't know much about this. The normal tip range that I see is between 1.0 and 1.8, but this gun has 1.8 and 2.2.
I need to pull the trigger on this soon so any advice would be appreciated. Also, the gun is brand knew in box in plastic.
bumpside
Re: DeVillbis HVLP Gun - Correct tip diameter
Post by bumpside »
http://www.sedco.co.uk/pages/nozzle_selection_guide.htm
This is a nozzle chart. Looks like there is not to much difference in flow between the two nozzles. Anyway, if the gun is a real good buy, I would get it and buy a different nozzle if I needed it
1972 SWB Ranger XLT
`We'll hold the distinction of being the only Nation in the history of the world that ever went to the poor house in an automobile.' (Will Rogers)
Hi Bjde0b, what work do you plan on doing with the gun?
As I understand it, larger nozzles (like 1.8 and larger) are used for thicker paints, like primers and anti-rust paint (Rust Bullet or POR-15).
I'm not sure what the drawback of the larger nozzle is, but people seem to want 1.0-1.5 nozzles for regular auto paint.
-Robroy
bjde0b
Post by bjde0b »
I have been doing my research and I have decided that the deal is not sweet enough. I want a gun with a 1.3 tip and is also gravity fed. The suction feed can spit and the 1.8 is too big and the 2.2 is definitely too big.
