351 M mounts
- 03rangerxlt
351 M mounts
Just found out my truck has a 351 M in place of the stock 360. Whoever did the swap did a horrible hack job, and used van mounts that are hacked up to try getting this to work. The motor is not sitting straight on the frames. and the fan got into the radiator and chewed it up. Does anybody know if anybody makes mounts to fit a 351 M in a '68 Ranger?
-John
1968 and 2003 Ford Ranger
"Honey, how 'bout I lock you up on charges of aggrevated dumb slut with no future?"
-Det. Ray Carling "Life on Mars"
"Criminals thrive on the indulgence of society's understanding."
Re: 351 M mounts
Just use the factory 302 frame stands....they'll work just fine. See the following link:
http://www.fordification.com/enginestands.htm
- fomocoguy
Re: 351 M mounts
Yup, Keith beat me to it, but the 302 stands are the same as the 351M stands. While you got the motor out you should do a cam change to a nice r/v cam and put a performance timing set in it to get rid of the factory 5* retard! With a cam swap, 500-600cfm 4barrel, and timing fix it would be a different animal!
Joe
1971 F100 flareside 8ft
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
2005 Ford Ranger
- thebannister8
Re: 351 M mounts
i've had both 351c and a 351 w , what's a 351m?
- thebannister8
Re: 351 M mounts
nevermind, heres the info >> http://www.projectbronco.com/History/hi ... d_351m.htm
- 03rangerxlt
Re: 351 M mounts
My mechanic is reworking the stock mounts with the welder and making them work. Its actually lookin' good right now. Damn I can't wait to drive my truck!
-John
Re: 351 M mounts
you should make that 351m a 400 and unleash some real torque
