The 67 project is in high gear
- 67F250CS
re: The 67 project is in high gear
The FMX to C-6 swap required a couple of mods but none were hard to do.
The bellhousing on the FMX is 3 times as thick as the C-6 so I had to put in shorter bolts. Easy enough.
The trans crossmember had to be moved back about 2 1/2 inches. ( Longer tailshaft) Will have to drill 2 new holes. Easy to do also.
1967 F250 Camper Special
10MPG with key off, in neutral and going downhill!
- 67F250CS
One more of the engine.
I learned the hard way that the header and starter have to be in at the same time. You can see in this pic its well behind the header.
- 67F250CS
The drive shaft from the donor truck as well as the carrier bolted right on my original rear drive shaft with no issues except drilling 2 new holes for the trans crossmember.
Damn! He's a man on a MISSION!
Good job....man, that thing is lookin' very nice!
This is looking sweet!!!!!
Isn't it great to work with CLEAN painted parts?
- flyboy2610
That is one sharp looking mill you have there!
I like the clean look. I'm not big on a lot of bling in the engine bay.
Red Green
you'd better be right.
Red Green
- 4x4x4crewcab
SWEET lookin good
Mark
1970 Ford F-250 Crew Cab 4x4 short box
1969 Volkswagen Karmann Ghia
1999 Ford Windstar
1983 Chevrolet Silverado p/u
1990 Lincoln Town Car
1998 Lincoln Town Car
Does your truck need emblems? Check out http://www.onceuponapart.com
1999 Ford Windstar
- 67F250CS
Painted a little today. Mostly inside the cab. Did a fender and the lower valance panel. It is hard to take pictures of paint and get the true colors so I put the ones up that most closely match the color I chose.
Its called Polo Green and looks a little more green than blue in person. Its a single stage metallic. Coming along nicely.
- 67F250CS
Couple more for the album.
- 67F250CS
Spent all day sanding the cab. About 6 hours. I am glad I will probably never have to do this again.
- trukcrazy
I'm very jealous!
John, #424
1967 F250 crewcab x 2.
2010 Dodge Ram 1500 Sport Quadcab
2008 Challenger SRT8
Man you are in high gear! Congrats!
- 69F110
- GT-Racer
- 67F250CS
Thanks for all the compliment and encouragement, I have to put it on hold for a year so I am trying to get as much done as possible. Leaving this Wednesday for the "sandbox"
