two barrel phenolic spacer needed.
ezernut9mm
Post by ezernut9mm »
who makes them and where to buy? i've had no luck finding one. i have a factory aluminium one, but it is warped. it took two gaskets on the carb side to seal it and i still don't think it's sealed right. the carb is true-i checked that and it is good. also, who makes good rubber vacuum caps that don't disintigrate after a couple of months like the autozone ones?
rubiranch
re: two barrel phenolic spacer needed.
Post by rubiranch »
Ford used them on 302s and 351s that were equipped with variable-venturi carburetors (2700 and 7200 VVs) from about 1979-1983.
Good luck.
:fr:
72 F-250 CS XLT 390 C-6 4.10 40k miles
You don't shoot to kill, you shoot to stay alive.
I don't carry because I have to, I carry because I get to.
http://www.fordification.com/galleries/ ... ?album=514
ezernut9mm
i'm gonna need it. i haven't found one in any catalog except for a rochester 2bbl. i wonder if the bolt patterns are the same. prolly not.
EZ,
For many years now I've taken the EGR valves and "gutted" them, plugged the 1/2" hole and used them for this. :thup:
Aluminum usually though, not phenolic.
rubiranch
Post by rubiranch »
ezernut9mm wrote:i'm gonna need it. i haven't found one in any catalog except for a rochester 2bbl. i wonder if the bolt patterns are the same. prolly not.
Nope, not the same bolt pattern. :(
