questions
OldRedFord
questions
Post by OldRedFord »
I need to ream the cylinders. Whats the best ridge reamer to buy/rent? If I buy one....under $120.
Also should I get a flex hone or a 3 stone one?
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
1971ford
Post by 1971ford »
i say flex hone but what do i know :D
for the ridges i used a scuffy pad and knocked them all down. there might be a microscopic difference, but im fine with it.
-Ryan
AlleyCat
re: questions
Post by AlleyCat »
If you don't plan on doing engine work on a steady basis then I'd suggest you rent a ridge reamer. There isn't a big call for them these days as most shops use reman crate engines. As far as hones go the ball or flex style hones do a better job in less time than the 3 stone version. The down side to them is you're pretty limited in size range. Different bore sizes require different size hones. With the old 3 stone versions one hone will cover a pretty broad range of bore sizes. :)
Clay
72 F100 4x2 Custom,289, C4 " Slow Ride "
70 F250 4x2 Ranger XLT , 360, C6 "B52 - IV"
96 F150 4x2 XL, 300, E4OD, daily driver
" Professional Wrecker Operators - We Pull for America "
OldRedFord
1971ford wrote:i say flex hone but what do i know :D
Is that a ok way to get rid of the ridge?
Tim
AlleyCat
re: questions
Post by AlleyCat »
If you can knock them down with a scuff pad you don't need a ridge reamer. The scuff pad will cut carbon buildup. A wear ridge in the bore metal would require countless hours and scuff pads to remove. :)
Clay
Thunderfoot
re: questions
Post by Thunderfoot »
Another trick for the carbon build up is to use Lacquer Thinner or Carb cleaner on it with the scuff pad, it dissolves/loosens it up. :)
Shayne
OldRedFord
Removed the other cylinder head and found one cylinder messed up. Think honing wont fix this?
Tim
1971ford
Post by 1971ford »
:eek: :eek: :eek:
wow, looks like that piston hasnt fired for a long time!
if that was mine i would want that bored out. that looks NASTY.
but it could be the pic, can you try getting a scuff pad and just try to clean up a little section to see if its really bad? is it just surface stuff?
-Ryan
OldRedFord
I was able to get alot of the rust off with some heavy scrubbing with a old toothbrush and purple power, and lacquer thinner.
Where it is now.
Tim
