A ? for a unknown light!!!!!!
I have a 69 f100 and there is a small light right above the parking latch; I have no idea why its there nor how it works. if any one knows whats up let me know.........thanks
re: A ? for a unknown light!!!!!!
It's a brake warning light. If you lose pressure in the front half or rear half of the hydraulic system it comes on to let you know there's something amiss with your brakes. That thing that looks like an "H" on the frame where the lines go is a pressure differential valve. The valve is centered and balanced by the pressures of the front and rear system. If the front or rear lose pressure, the valve goes off-center and trips the brake warning lamp switch that rides on the valve. It also goes off-center when you bleed the system and can be a real pisser to recenter, especially if you're doing it by yourself. A lot of times people just disconnect the plug to the switch, not the best idea.
There is more about the differential valve in THIS THREAD.
- willowbilly3
On my truck that light only comes on if I have a cracked di-lithium crystal, or a massive polar degeneration in the ion fields.
Really it should be connected to the brake equalizer valve and light up only if there is an imbalance between the front and rear brakes system hydralic pressure.
- 67F250CS
Everytime there is a disruption of the space-time-continuum mine lights up.
Actually, Like Keith said its a pisser to make it go off. Bled my brakes in early March and still messing with it.
1967 F250 Camper Special
10MPG with key off, in neutral and going downhill!
- willowbilly3
Re: re: A ? for a unknown light!!!!!!
So going backwards through a worm hole is the only way to make it go out.67F250CS wrote:Everytime there is a disruption of the space-time-continuum mine lights up.![]()
- 67F250CS
- granitestate68
http://www.fordification.com/galleries/ ... p?pos=-550
1996 F250 Slightly lifted 7.3L Diesel
1961 Falcon Ranchero 144 Inline 6
- 67highboy
I had slight leakage in my warp core and that dang light came on in my rig as well
People who are willing to give up essential liberty to purchase temporary safety, deserve neither liberty or safety...
Ben Franklin 1775
Ben Franklin 1775
- granitestate68
67highboy wrote:I had slight leakage in my warp core and that dang light came on in my rig as well![]()
Sure hope you got Scotty to give you a little more "Powa" and I'm sure "Bones" is helping with the wounded. I'm sure Ohura is kinda like scratching her head waiting for Checkov to turn the wheel and Spock is just waiting to get them both in the transporter to give them a "mind meld" . Wow, talk about memories.
- willowbilly3
Dammit Jim, I'm a Doctor, Not a mechanic.
- GT-Racer
lmao
'67 F100 2wd shortbed - Beginning restoration.
351w, 5-speed, 3:70 gears (someday)
Drivin' a Chevy is Kinda Like wipin' before you poop, it just don't make no sense....
- 91Bear
My light only comes on when I have trouble with my flux capacitor. One time I went back to 1955 and that thing went crazy!
I met a really cute girl, though...but she turned out to be my mom.
- willowbilly3
Geez, I hope your not like your own dad or something.91Bear wrote:My light only comes on when I have trouble with my flux capacitor. One time I went back to 1955 and that thing went crazy!
- 91Bear
- 68F250
Ever touch that light after its been on for awhile?
Barry
