Cream color primer?
wolfpack
Cream color primer?
Post by wolfpack »
hello group sorry haven't been around been crazy around here, haven't had much time with even working on my truck , I was wondering how you get that cream color primer? Thanks Terry.
tubewatts
re: Cream color primer?
Post by tubewatts »
I think you mean epoxy primer.....any auto body supply house....
Recognition is the key to discovery
FoMoCo
Post by FoMoCo »
Dupont has a economy line of products called NASON. They have a two part primer thats a vanilla milkshake color 481-28, i think?
Nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
67F250CS
Post by 67F250CS »
A freind that did mine said its nickname was "Europrime".
1967 F250 Camper Special
10MPG with key off, in neutral and going downhill!
wolfpack
Post by wolfpack »
thanks guys i will check into that fomoco that's exactly what i was looking for. Terry.
big_blue_72
Post by big_blue_72 »
PCL makes a cream colored primer its called buff very awesome primer at a very good price i recomend this primer to everybody it fills 77 to 1 sands and blocks killer best to reduce it with a lil bit of acetone very thick stuff works wonders :D
tcb1969
Post by tcb1969 »
The product you are talking about is made by DuPont and is called URO-prime (uro is for urethane) it is a "high-build" primer/sealer. High-build means it contains more solids than standard primer. It can be used as a primer but can be additionally thinned and used as a sealer also.
Personally, I use it on all my paint jobs. It can get expensive - by the time you buy activator and thinner - it's around $120-150 per gallon (including the chemicals to mix).
It's available in grey, oxide (red), tan and black. Because it is urethane it will seal against moisture - you can prime and not paint over it and it won't rust for a long, long time.
John
67F250CS
Post by 67F250CS »
Thanks, I thought Europrime sounded funny. :D
