Fixing Dents In Bed
Fixing Dents In Bed
Is it possible to fill the dents in the bed as they are with filler, then cover with some sort of liner? Line X, Herculiner, etc... If this stuff isn't supposed to crack or anything the bondo shouldn't crack or pop up. So will this work?
re: Fixing Dents In Bed
Actually, I've kinda been wondering the same thing. I don't see why it wouldn't, but good surface prep would be critical here...no shortcuts allowed. And you'd probably want to try to keep the filler thickness to a minimum, so if there were any deep dents, you'd want to tap them out as much as possible first. I'd also think you'd want the higher-quality spray-in liner rather than the inexpensive roll-on liner kits.
From what I've learned lately, I believe you could just do the dent repair like you would any other body panel, then spray the bed with a good etch primer and then coat with the spray-in liner.
- 67F250CS
derrabls
Where do hang your hat?
Im over in Oak Grove myself.
Shoot me a message some time.
1967 F250 Camper Special
10MPG with key off, in neutral and going downhill!
- morganater
It looks like the back of my truck was hit with a giant-sized hail storm. I dont plan on fixing all the dents, and the ones on the very rear sides you can't get to to hammer out. Filler in the bottom rear corners wouldn't be a terrible practice imo.
1969 f100 swb ranger 460 - parting out
1968 f100 swb 429 - decking out
94 Jeep I6 Back-up vehicle
reppin' AK
reppin' AK
Yes it can be done!
The Dealership I use to work for did spray in liners (brand line-x)
We fixed dentd wth bondo and you dont have to have it perfect because the liner is thick enough to cover your scratches! We would take tape and cover small drilled holes and spray over it! You dash pad guys will love this! I took a busted up dash pad that looked like crap, I covered it in bondo, then smmothed it out good! They sprayed it and it looked great! I am about to do my 1967 pad that way! I will post pics when its done!
I have several things to post pics of when my wife shows me how!
FORD BUILT EM TUFF WE BUILD EM BETTER!!
- morganater
umm Bcooley so ur saying u can take a VINYL dash pad and spray automotive paint on it, and it will be reliable?!
reppin' AK
reppin' AK
No, what I am talking about is having a vinyle dash (thats all cracked up)
Srayed with bed liner spray and you will never know it was cracked!
I always spread bondo over the busted up pad to smooth things out and then get the local line-x dealer to spray the pad! It gives it a good custom textured look!
Re: re: Fixing Dents In Bed
How much do they charge you for that?BCOOLEY wrote:No, what I am talking about is having a vinyle dash (thats all cracked up)
- Joshpow
Hey good post here. Brought up an interesting fix for those cracked dash pads as well as the dents in or beds. Definitely post pics of the dash pads and let us know.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
I will post them! I plan to have it done next week! If it turns out ok I would be glad to do others for members! (at cost)
I saw a segment on that line-x product on "Trucks" and that stuff is indestructable, plus they can spray on a smooth finish. So I'm interested in seeing those pictures when you are done.
Personally, I'd use fiberglass instead of bondo mainly because it would be a lot stronger. The spray-in liner would probably hold it all together, but I'm not sure what would happen if the bondo came loose under the liner. There's even stuff called fiber-strand at NAPA and other stores, that's similar to bondo, but uses fiberglass strands for strength. There's a short and long strand versions.
Jeremy
1971 Ford F250 CS, SC, 2X4, 390, C6
