#16 - Sept. 30, 2007
OK, here's another one for you all. All trucks use these. The washers are (should be) a give-away, since AFAIK there's only one spot that uses this style. What are they used for?
- theskytoucher
Re: #16 - Sept. 30, 2007
um holding that thing together!!!!!FORDification wrote:OK, here's another one for you all. All trucks use these. The washers are (should be) a give-away, since AFAIK there's only one spot that uses this style. What are they used for?
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
1976 Ford F-150 4x4
- JWW
re: #16 - Sept. 30, 2007
They look like cab mount washers.
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
My project: http://www.fordification.com/forum/view ... &sk=t&sd=a
2004 F150 Crew Cab
- JWW
Re: re: #16 - Sept. 30, 2007
Scratch that, looks like washers and bolts that hold the steering shaft bracket in line.JWW wrote:They look like cab mount washers.
JWW
2004 F150 Crew Cab
2004 F150 Crew Cab
- AustinTom
Yep, you got it! These are the bolts and cup washers that hold the steering column mounting bracket to the outer side of the firewall.JWW wrote:...looks like washers and bolts that hold the steering shaft bracket in line.
This one was actually kind of a trick question. While all trucks do use three bolts with cup washers here, some trucks have slightly different styles of the cup washers. Some are round and some are 8-sided, but it's been my experience that the style I pictured above is the most common.
- JWW
I knew they looked familiar. I just removed my steering column.
JWW
2004 F150 Crew Cab
2004 F150 Crew Cab
