E-Brake light in cab won't go out
ryans51
Post by ryans51 »
I've got a '68 with an annoying light in cab that I can't get to turn off. It is the small red light in the lower left corner of the instrument pannel, next to the light switch.
I assume that it is for the E-Brake since it says brake on it. My question is where is the switch for that light?
Thanks for the help
Ryan
'68 F-100 LWB
'92 Mazda Miata
mrsnicks
Post by mrsnicks »
Your assumption is incorrect... it is not for the emergency break. It is for balance between the front and rear brakes.
It's telling you something is off in the system, basically, from what I understand you have to bleed your system until the balance is right again..
I know that doesn't make a lot of sense, hopefully someone else can chime in with more.
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
71 LONG BED
re: E-Brake light in cab won't go out
Post by 71 LONG BED »
I haven't had this problem myself, but yes, your brakes are not working properly and that is a warning light!!! The system needs to be "balanced" at the very least, but you really need to find out why it is off balanced.
John Member #1549
Image Image Image
theogre5150
Post by theogre5150 »
You can do what I did, remove the bulb until you have a chance to balance the system. :thup:
bugser
Post by bugser »
The light in my truck was gone long before I bought it. I don't need it though,my brakes are definitely not balanced.
:o
RON
Excuse me while I whip this out
flyboy2610
Re: re: E-Brake light in cab won't go out
Post by flyboy2610 »
bugser wrote:The light in my truck was gone long before I bought it. I don't need it though,my brakes are definitely not balanced.
:o
:yt:
Red Green
you'd better be right.
jor
Post by jor »
I copied this from one of Keith's posts on this issue.
jor
Turn the ignition switch to the ACC or ON position. Loosen the pressure differential valve inlet tube nut of the unfailed system, or the side opposite the system that was bled last. Operate the brake pedal carefully and gradually until the pressure differential valve is returned to a centralized position and the brake warning light goes out. Tighten the tube nut.
Here's a couple of illustrations from the same thread, both Keith's.
bugser
Post by bugser »
So....in order to verify that my thingy is centered,I'd hafta install a bulb in that thingy on the dash?? :eek: Ah...skip it.
I just flushed the system today so the pedal definitely works better,as in,no bottoming out. I think it will be even better when I put new shoes on. :thup:
RON
bugser
Post by bugser »
Flyboy....there's one thing I never do in my truck...tailgate. :D
RON
