Speedo cluster question
Bugsb70
Post by Bugsb70 »
The light bulb in my speedometer is out. It should be simple to remove the four screws, pull the cluster forward and disconnect the speedometer. It isn't. Does the speedo cable screw on or is it help in with a clip like models after 1973? Suggestions on how to make this removal easy? I don't go around just pulling stuff.
oltrukr
re: Speedo cluster question
Post by oltrukr »
Reach up behind the cluster and unscrew the speedo cable, remove the screws from the face of the bezel and remove it from the dash. All the bulbs are easy to access.
Craig
http://profile.imageshack.us/user/oltrukr/
'72 F250 Camper Special Sport Custom 390 C6
'70 F250 Explorer Special Camper Special 360
wt4speed#2
Post by wt4speed#2 »
Speedo cable screws in , and that is how I would do it but I think there are slightly more than 4 screws.
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
'69 F-100 "Stepper"(currently in a bigillion pieces )
wt's ride
thebucket
Bugsb70
Post by Bugsb70 »
Question answered. Thanks
