STICKY: Best mods or upgrades you have done to your bump?
- tude
Re: STICKY: Best mods or upgrades you have done to your bump?
seats with head rests! i hate not haveing a headrest....
note to self bronco seats dont fit well....but i dont go far in mater
custom fit hammered and bent
The best ones I have done to this point are power steering and electronic ignition. More to come with the 75 front disk upgrade and some suspension mods.
my fav is the antique brass door knob turned shifter knob
1971 short bed ranger Frankenstein (restoration and customization in progress)
Two words: Three ninety
2012 Chevrolet Silverado 2wd 4.8 ls auto
2002 Toyota Sequoia 2wd 4.7 auto
1985 GMC 3/4 ton 2wd 350 automatic
1979 Chevrolet C10 350/TH400 14 bolt "Big 10" (DD)
1971 F100 2WD LWB 302 T18 3.70 9inch PS PB
1970 VW Type III squareback cut into pickup dual carbs
1967 Ford F100 LWB 352 3.03 9inch
1967 International Travellall Panel truck
1966 International Scout 800 4X4
1964 Chevrolet C10 on 1986 4X4 frame 350 700r4
1958 Chevrolet DelRay 235 3 speed
1954 GMC rat rod project Scout frame, inline 6, T90 4X4
1953 Chevrolet Tin Woody
1946 Hudson BigBoy Pickup-ratrod project
- elgemcdlf
The best mods I have done to my bump is a combination. One without the other wouldn't work. Swap out the front suspension for a 2005 CVPI IFS with 1 1/2" drop springs. The other half: 1995 Thunderbird (MN12) IRS.
- cheek
Definetly the lokar shifter I got installed, looks great and is sooo nice to use! Oh and getting the lpg (propane) system tuned.
1970 Ford F100 351C FMX Daily
1972/3 Ford F100 Project
- 1971ford
I am in the process of Restoring my 1972 ford F-100 and I have done a bunch of custom modifications. The most Interesting one is my plans for a New feature upgrade which gives me Temperature Inside and Outside with True Heading mounted on a panel to cover the old radio hole.
The Upgrade will hopefully include:
An Arduino micro-controller to read temperature inside and out
A 4x20 alpha numeric character display to show everything
A magnetometer to create the digital compass.
As time goes on I think i want to use two hobby servos to control the defrost and floor heat vent and another one to control the hot air cold air mixture. I wan't to implement an In cab thermostat controller that will control the temperature inside the truck.
Either way you can track my progress here along with the rest of my restoration progress.
http://classictruckguide.com/2011/1972- ... -upgrades/
Cheers!
Joe Hoffman
Cheers!
Joe Hoffman
- thrush544
Hey tude, your seats look great!by tude on Sun Jul 10, 2011 1:06 pm
For mine I'd say it is the Torque Thrusts & Firestones.
God Bless
"Courage is being scared to death, but saddling up anyway." - John Wayne
Proverbs 3: 5-6
Proverbs 3: 5-6
- evan_flatt69
Adding an auxiliary plug to my stock radio was pretty neat. Get the tunes I want with a stock radio. Then that wasn't enough so I added a standalone PC sound system in the back of my seat, which is very useful.
1969 F-100 Short Bed Custom Cab 390
1985 BMW 635CSi
1985 BMW 635CSi
rebuilt 460 from the block up with ground exhaust ports on cylinder heads new lifters and a shift kit for the C6 tranny. workin on painting the truck white ((doin it myself)).
- Joshpow
2k2 f150 seats and tilt column!!
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
Replaced a tired and weak 240 I6 with a 352FE, power steering, pertronix ignition, dual exhaust turns out in front of the tires.
Things to come C6 auto, tank moved to under the frame, power discs up front, (Still considering the cv front end swap), new paint, stereo, and a/c.
- 1972hiboy
Took the lame headers off my 4x4 f250 and put nice cleaned up exhuast manifolds on. I can acualy change the starter now! Best urgrade by far!
Rich
Dont eat yellow snow.....
- 1970 Hi-Boy
- Location: Middle Tenessee/Northern Wisconsin/wherever else I may roam to try and make a buck.
Absolute best mod I had made was have the radiator recored to a full four rows, sometimes referred to as the "dessert" radiator, and installed an overflow catch bottle. No more worries going over mountain passes, or running hard on a hot day. The second best and biggest modification I've made was to get rid of the water world of heater hoses going everywhere and under the carb and plumbing the heater core like normal, I like the heat in the cab! I cut the connectors off the carb spacer, just in case I ever got the notion to put it back, also installing a heavy/thick insulator gasket underneath the carb. A Walker Sound FX muffler makes it sound cool outside and hear the radio inside which is another mod with speakers. An old school compass and some gauges that work in the cab, and new air cleaner, hotter coil and an electric choke about round it up. What else can you do to a truck made near perfect to begin with? Best thing I did to my truck while not a mod, was to finally find the power steering pump filter, the original FOMOCO one was in there for over forty years! That old Eaton pump sure was happy, and I was too, sure is a lot easier to steer now.
1970 F250 Sport Custom 4x4 360 V8, otherwise known as the Hi Boy, and a Harley-Davidson.
1953 Lincoln SA200 portable welder with a 4 cylinder 1941 Continental F162 engine.
"If you think you can do a thing or think you can't do a thing, you're right." Henry Ford
