Homemade headliner
mjhaltom
Homemade headliner
Post by mjhaltom »
Has anyone made their own headliner out there? I want a black headliner, but I am not willing to pay what LMC wants plus the shipping charge. I have the old damaged one to use as a template. What would ya'll suggest I use to cut out a new headliner?
2015 lifted Toyota tundra 4.6 4wd
2002 Toyota Sequoia 2wd 4.7 auto
1989 Ford F150
1979 Chevrolet C10 350/TH400 14 bolt "Big 10" (DD)
1972 F100 parts truck long bed
1971 F100 2WD LWB 302 aod 3.70 9inch PS pb
1966 International Scout 800
1954 GMC rat rod project Scout frame, inline 6, T90 4X4
1953 Chevrolet Tin Woody
1946 Hudson BigBoy Pickup-ratrod project
masonite would be a good flexible material or even flooring underlayment would be flexable enough.
gonzalo medina
re: Homemade headliner
Post by gonzalo medina »
Don't waste your money on a lmc headliner. You go to home depot or arts and craft store and buy a sheet of paper board. It's no thicker then a quarter inch and use your old one as a templete to trace then just buy fabric glue and buy a roll of what ever fabric you like and smooth all the rinkles out and let it dry for an hour. You shouldn't spend more then 30-40 dollars.....good luck
ladz
Post by ladz »
We did ours with 1\8" Masonite and covered it with 1\4 foam padding and then put the fabric on that ,it went well but if i were to do it again i would bend the ends a longer time and use water or steam !
Jake11
Post by Jake11 »
Gots pic's? I'm interested.
460 crew
Post by 460 crew »
I made mine from headliner board from a local upholstery shop along with a can of contact cement to glue my headliner foam/fabric to it, they had a ton of colors to choose from. I used my old liners as templates and they have been up for about 3 yrs with no problems. I think the total price for the 2 of mine for the crew was 50 bucks.
67F250CS
Post by 67F250CS »
I made mine from a donor van's headliner. The van I used is a 96 Dodge Caravan. Its tough but flexible enough to bend into shape and it had 2 dome lights in it. It a thick multilayered cardboard and trims easy with a razor blade. I have some pics if interested.
http://s115.photobucket.com/albums/n281/1967F250CS/
1967 F250 Camper Special
10MPG with key off, in neutral and going downhill!
rjewkes
Post by rjewkes »
I'm thinking of doing a nice headliner board and puttin in some padding and crushed velevet diamond tuck. and also putting in an overhead console.
fuelly.com
jhannahokla
Post by jhannahokla »
i made mine out of a piece of card board and stapled a flag to it
James
1970 F-100/302/3spd/9 Inc RearEnd 3.50 G/R
Image Watch This BurnOut !
cj is that you?
Joe Kriston
Re: re: Homemade headliner
Post by Joe Kriston »
ladz wrote:We did ours with 1\8" Masonite and covered it with 1\4 foam padding and then put the fabric on that ,it went well but if i were to do it again i would bend the ends a longer time and use water or steam !
I wondered about that...I want to redo mine in matching seat vinyl,but I didn't know if I should pre-bend the corners so it fits nicely into the surrounding metal strip,or if tightening the screws on the metal strip would be enough to get the headliner to match the contour of the roof...
ladz
Post by ladz »
Jake 11 i will get some this week end ! I will be doing the door panels !
ladz
Post by ladz »
Hi joe, i did not bend it before i installed the liner , but what i did do is make some clips to hold my liner up so i could work the corners in . If you look at my up dates we did the seat black with a dove gray insert ! the liner is the same gray , i made kick panels also . The 1\8 board was ease to form and work with ! I would think if you wet the ends and laid it on a horse and let the ends hang over and weigh them down it would bend and stay after it dry ! But , by not bending and pushing into place you do not have to secure the center and it is very ridged and there is no need for center support . It really turned out nice a couple of people picked up on it with out me mentioning the liner a all !The clips i made were in the shape of and " S " one side clipped on the truck steel where the head liner goes then i lifted the liner up in place into the clips and then worked the back into place! if you need more info let me know i will see if i can get some pictures and send them .
rjewkes
Post by rjewkes »
Could the old peg board style be used as a backing board?
And could it also be screwed in to make a speaker mounting point down by the gas tank?
fuelly.com
Joe Kriston
Hey,Ladz,if you got any pics,I'd be glad to see them...I'll pm you my e-mail addy...
