squeaking
squeaking
when i accelerate in my truck from a stop or pretty much any speed in 1st gear my truck starts to squeek it sounds to me like it is coming from the back of my truck.
re: squeaking
Might also help to know what kind of transmisison you have.
re: squeaking
it starts off kinda chirping slow it will go faster as i speed up and then it will just stop once i get outta first i have a c6 tranny.
- SmokeyBear
you have mice
http://www.automobileforum.com/forums/u ... 379036.jpg
j/k I'd put the rear end on jackstands and put the truck in neutral and turn the rear wheels. Be safe though.
70 F-100 XLT
"Christine" Gone but not forgotten.
72 F-100 Ranger XLT
72 F-100 Ranger XLT
- 68F250
re: squeaking
The squeaking and chirping will stop when the U-joint breaks and the driveshaft falls out.
Barry
re: squeaking
Could be pretty exciting too, depending on just how fast your goin.
And which end comes out... if the back comes out it will just drag... if the front comes out.... Well, are you a big fan of pole vaulting?
Patrick
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
re: squeaking
There was an episode of MythBusters where they were trying to duplicate that very scenerio....where the front U-joint fails and drops down, pole-vaulting the car into the air. They rigged up a remote-control car and took it out onto a large parking lot, and then using another remote control device was able to 'blow' the front J-joint on command. They had a HECK of a time getting anything to happen! The one time they were able to time it just perfectly by letting the driveshaft drop down into a pothole they did have some success, but nothing like you'd expect. Pretty tame, actually. I believe they considered that myth busted...or at least plausible but unlikely.
- 72hiboy4x4
- Location: As far away as I can be from Wa state, without crossing the Mississippi
I saw a 4x4 truck with a trashed frame just like that when I was younger.
Happened exactly like that. broke the front joint on the rear shaft and it dropped into a hole. pushing the rear axle almost out of the truck before the shaft bent up like a pretzel.
re: squeaking
that would be awsome to see it happen or driving when it happend but it would suck because id have to fix it...
