Speedometer not working
rs2600
Post by rs2600 »
I have a -70 4x4 short bed, 390/4 speed and can't get the speedometer to work. Using a powerdrill at the end of the cable (at transmission end) will get it working and the plasic gear drive is good but when I put the cable back in the trans nothing happeneds. What's wrong.
Any input appreciated.
Thanks,
Mat
maybe a stripped or loose gear on the tail shaft.
rs2600
Post by rs2600 »
fordman wrote:maybe a stripped or loose gear on the tail shaft.
How hard is that to fix?
you'd have to take off the tailhousing and look at it. thats about all i know for sure.
heep70
Post by heep70 »
On the end of the cable isn't there a flat spot or a tab that fits into the gear? I am just throughing something out there. I don't remember if the ford cables are made that way. I just did my Toyota and I do remember there was a tab at the end of the cable that fit into a groove in the gear.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
rs2600
re: Speedometer not working
Post by rs2600 »
Well, the tab and the plastic gear are fine so the problem must be within the tailhousing. Question was, how much work is involved in removing the tailhouse?
i think its just four bolts and removing the drive shaft yoke and maybe jack up the transmission.
