trailer wiring
green71F100
trailer wiring
Post by green71F100 »
Has anybody wired their truck for a trailer with a flat 4 connector? I'm needing any help that you all can give as to what wires/color/tracer on the truck you tapped into.
heep70
Post by heep70 »
I have done mine, but is has been a long time ago. I used a volt/amp meter and a striaght pin and jabbed the wire to find the correct ones. If I remember right it was pretty simple task.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
bluef250
Post by bluef250 »
Try this site:
http://www.accessconnect.com/trailer_wiring_diagram.htm
There are several other sites. One bit of advice is not to use connectors that clamp onto a wire. While easier and quick, they just do not seem to work as well as crimped and soldered connectors. The guillotine conenctors tend to loosen from vibration and then you have intermittent connections. Also, they break the insulation allowing a route for corrosion. :2cents:
68F250
re: trailer wiring
Post by 68F250 »
What's nice is the wires are the same color code.
Barry
green71F100
Re: re: trailer wiring
68F250 wrote:What's nice is the wires are the same color code.
Seriously? Brown to brown, yellow to yellow and so on? Could it really be that easy? :eek:
68F250
re: trailer wiring
Post by 68F250 »
Yep! :thup:
Brown to Brown - taillights
Green to Green - right stop and turn
Yellow to Yellow - left stop and turn (I think the truck's yellow wire has a black stripe)
Use the frame for your ground.
Barry
