Steering Box
Steering Box
The steering box in my 1971 Ford has "FoMoCo" stamped on it so I know its a Ford part. How can I tell if it was the original box that came stock with the truck? The steering column is not original and I need to change it out so it would be helpful if I knew whether the box was stock or not.
- lobuck76
re: Steering Box
You can find pictures of the steering gearboxes and columns in the tech papers, power steering install. The ford box was the same from sixty-something up through '79 on the 2 wheel drive models.
'71 F-100
