Dome light repairs... How Ford should have done it
LANCE65
Post by LANCE65 »
WOW! I have a ways to go. I am on page 6! Thats ok though :wink: , I still dont have FORD! :doh:
2015 Camaro-2001 GMC Safari-1984 F250 6.9/T19 2wd-1974 Dodge D100 short fleetside~ 72 wife ~ late model kids, a Chocolate Lab named Coco and a white rabbit named Marshmallow...now I need a ferret named Graham and I will have S'mroes!!!..lol :D
Worked on the second batch a little bit again tonight, but must have been pushing a little bit because I snapped off two 1/4" end mills in the same peice... I'm doing the steps in different order this time, trying to do all of the inside cuts first and then doing the outside cuts last so I don't have to worry about dinging them during the later processes. I also decided to use a stop block and vise to hold the part vs the fixture I used last time. It's working out better with more cut time vs parts swapping time. As this is a learning process I found out the hard way that the band saw isn't cutting straight because when I flipped the part over to do the step cuts on the bottom the reference stop isn't at the same spot on all the parts. The resulting shift kept the lenses from seating correctly so I increased the feed speed while reworking the part for more clearance. Took a couple parts to finally toss the thin stop bar and replace it with something full width and that worked great for 23 parts. On the 24th I was off again so I sped up the feed rate to 15IPM again to chase the part (reset it in the vise a couple thousandth of an inch off the stop). Only problem was on the 25th part I forgot to slow it back down to 10IPM and snapped off the new mill bit from overfeeding. Luckily it didn't damage the part so I put the old bit in the holder and reset the Z reference, but it was too dull to run a 10IPM and snapped off about three inches further than the first (I didn't even think about slowing it down)... Figured it was a good stopping point so I cleaned up and walked away.
I figure on the next batch I'll mill one end off of the blanks for a good refernece and 99% of the problems will go away.
Jamie
1971ford
Post by 1971ford »
i cant understand "mill talk" lol
i guess me being on the end of the list is a better thing, since there is less slight imperfections :D
keep up the good work :thup:
I cant wait!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
-Ryan
I'm just exploring different ways of doing things to find the most efficient way. Using the fixture required me to bolt down each piece before machining, figure a minute in and a minute out vs 30 seconds to blow the part off, loosen the vise, make sure there are no chips on the parallels (that the part sits on in the vise) and lock it back down. Only problem is with the vise you have to have something for the part to rest against so the part's center matches the mill's center or the X dimension gets offset. The right side of the part was referenced against the stop for each process and since the right sidebandsaw cut wasn't perpendicular when I flipped the part over the X reference was off on the bottom cut. The tolerences are probably too tight because a couple thousands of offset kept the lens from fitting. It's nothing you'll notice from a foot away, but it's still too much for the lens tolerance so I had to rework it. It's all a learning process.
Jamie
Supermike
Post by Supermike »
Sounds complicated to me... lol
How did those lenses come out of the sandblasting??
Former owner of a '67 F100 Camper Special
Current owner of a 2022 Ford Bronco Wildtrak
The lenses turned out really nice. I shipped off the first batch this morning. Rode by the post office yesterday and they were swamped so I was waiting when the doors opened. I'll try to get the second batch done before Christmas.
Jamie
nadams
re: Dome light repairs... How Ford should have done it
Post by nadams »
I can't wait! I hope that I'm in the next batch. Keep up the good work Jamie. :thup:
Hi, I'm Nathan and I approved this message.
1968 F250 LWB 360 (now 390) 4 sp High boy mine
1999 Expedition Eddie Bauer Edition 5.4 liter girlfriend and daughters
sideoilerfe
Post by sideoilerfe »
I think I'm in the 2nd batch. It's gonna be great. :thup:
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
Dang Ya'll!
Got my Ranchero50 deluxe dome light lens in the mail today!
These thing are the cat's meow!!! :thup:
Jamie, you really oughta' do this:
http://www.uspto.gov/
Excellent job, thank you so much!
Supermike
Post by Supermike »
Hopefully I'll get mine tomorrow, then!
Fake Name
Post by Fake Name »
Got mine today, looks great, thanks!
fn
PS: Anyone researched an LED solution for the light itself? A little brighter would be good...
1970 F250
2011 KTM 990 ADV
2003 KTM 525EXC
BobbyFord
Post by BobbyFord »
Too late to put me down for two???
BobbyFord
Post by BobbyFord »
Fake Name wrote:Got mine today, looks great, thanks!
fn
LED replacement bulbs are available for just about any automotive light including dash bulbs...
http://superbrightleds.com/1157.htm
1971ford
Post by 1971ford »
maybe one of these? i dont know, i havent looked to see what exact bulb is in the domelight.
http://superbrightleds.com/BA9S6_specs.htm
-Ryan
That's great that they are showing up, thanks for the comps. I worked on the second batch from 7-9:30 last night and should have the machine work finished tomorrow. I'm surprised you want brighter bulbs, I thought it was blinding when I put the lamp on a charged battery for the picture.
Jamie
