The official 6bt conversion thread
averagef250
Post by averagef250 »
You want to find the ZF small block version S5-42 5 speed. The six speed is $$$$$$. The instructions for turning up the governor on the 4BT with a VE pump is on the link in Nevrenfup's signature line.
nevrenufhp
re: The official 4bt conversion thread
Post by nevrenufhp »
http://www.dodgeram.org/tech/dsl/more_p ... wer_ve.htm
is how to crank up the fuel, and you'll have to get a replacement spring for the governer if you want it to rev higher than 2700(most people do). Those are readily available for under $20 usually. The new spring is availavle in 3200, 4200, and higher rpm.
67 F100, 300(Offy intake, Edelbrock 500, 274*/.518" lift cam, heddder, duraspark & Summit CD ign), 4spd, power steering swap, front disc and hydroboost.
08 VW R32
increase diesel fuel rate site:
http://www.freewebs.com/nevrenufhp/index.htm
mljjones67
Post by mljjones67 »
nevernuf here is the link to Dens spring upgrade. The one on your page doesn't work anymore.
http://www.dens-site.net/Dodge_CTD/Governor_Spring/
nevrenufhp
Ok, thanks...I just changed it.
08 VW R32
mljjones67
No problem.
Good information!!!
Bunch of 4bts coming up on the next dovebid auction... Chevy drivelines though. May watch just to see what they go for.
Still eating popcorn and watching this thread... Did manage to clean some of the gunk off the 6.9 yesterday. Looking at mid August for the swap :)
Jamie
averagef250
Finally... Here's some 4BT bumpside pics of my '71. The truck needs a bath, but the pictures give an idea atleast.
averagef250
If there's anything else you guys want to see let me know.
460 crew
Post by 460 crew »
Looks great!! All that extra room. :D pics of tranny and mount, is it married to a 205?
mljjones67
Holy crap there is alot of room in there! I like it. Plenty of room to stand in front of the motor and work on it!
Awesome pics Dustin
averagef250
I can't get a good angle on the ground to show the tranny. I'll get it on the rack and take some pics for that. The t-case is a BW 1356. Not my first choice, but the goal of this truck was to look pretty and pull down MPG. The mazda 5 speed and 1356 do that pretty well. Actually, now that I've driven it quite a bit I've got a lot more respect for these parts. They're holding up real well to everything I do with it.
The tranny mount is the stock one. Ford's used the same tranny mount bolt spacing and size from the 60's through 2008. I just dropped the crossmember onto the lower frame lip and had to modify it a bit for front driveline clearance. The picture shows that part.
One things that's not arguable is how much attention this truck gets. Everyone stares. I get used to just popping the hood and leaving it up when I go somewhere.
mljjones67
Dustin can you get a pic of the engine stands and mounts????
nevrenufhp
averagef250 wrote:....
.... is how much attention this truck gets. Everyone stares. I get used to just popping the hood and leaving it up when I go somewhere.
At least it's for a good reason, not, "I hate you and your gas guzzling old truck!"
Clatter clatter!
08 VW R32
Redcap
Re: re: The official 4bt conversion thread
Post by Redcap »
averagef250 wrote:Finally... Here's some 4BT bumpside pics of my '71. The truck needs a bath, but the pictures give an idea atleast.
Wow! :eek: :eek: :thup:
That made me abandon my PSD thoughts! There is so much room in there! :eek:
Guess I have to find a 4BT or 4BTA now!
averagef250
Here's a couple frame stand shots for you Mike.
A clean old lifted highboy gets looks going down the road period, but this thing makes you feel like a celebrity!
The 4BT is cool. Nobody has anything bad to say about them. People are always suprised when they hear it first then they find out what's in there and see for themselves just how big it isn't. It moves the truck down the road great. While it doesn't have burn the tires power it more than makes up for that with rediculous low end torque. I like it. I'm still going with the six in my '70, but the 4BT truck might stay on as my economy car. How many can say that? "Yep, with the price of gas these days I had to downsize to a 5500 pound lifted highboy".
