1970 F100 Frame and Powertrain Swap (to 07 CrownVic running gear)
Monkey-1
Re: 1970 F100 Frame and Powertrain Swap (to 07 CrownVic running gear)
Post by Monkey-1 »
Good looking project. Keep the pics coming.
-Monkey-1
Studmonkeyracing.com
studmonkey@bellsouth.net
biggurn
Post by biggurn »
Thank you. I'll keep them coming. :D
Another big day for Floyd. I was able to get the cab cross member and rear wall notched and the filler panels welded in.
From there, I made two plates with welded nuts to secure the cab front. Welded those in place and painted them up... oh, and yeah, the cab is on the chassis!!!
Next will be getting the rear cab support built and welded into the frame. As of right now, I have 14 hours invested.
The Fords:
2016 SuperDuty F350 LWB Crew 6.2L
2019 Ford Expedition Max 3.5L
1993 F350 LWB Crew 460
1988 Ford Bronco II 2.9L
1970 F100 (full frame swap Crown Vic Underpinning, LS Powered, 4L80E)
1968 F250 Highboy (LS Powered, 4L80E)
Youngfordkid
Post by Youngfordkid »
I still feel like crying about that frame....
Bullitt74
Post by Bullitt74 »
:pop: Subscribed!
Keep the pics / progress coming!
Steve F.
Red Deer, Alberta, Canada
8)
Manny
Post by Manny »
Looks good glad you got the cab mounted keep it up!
biggurn
Post by biggurn »
Spent a little time working on the truck today. Built the rear cab support, it is 1.5"x 3"x .125" wall tubing. Made sure to weld sleeves in where the bolts will pass through to avoid crushing it. Welded it in place and then sprayed some under body coating to protect everything. My order from SummitRacing arrived with the joint for the steering, so I was able to hook the steering up and check that off the list! Finished the afternoon off by installing the cable operated throttle body and a 6G 140 amp alternator for a 98-2002 CrownVic (does not require the ECU to work). The cab will need to come off one more time to install the Lokar shifter, after that it can go into place for good and I can start on mounting the front clip!
I'm up to 17 total hours invested.
The Fords:
hfdco4
Post by hfdco4 »
Amazing work. Did you figure out what happened to your "cats"?
:fr: FE390PC
biggurn
Post by biggurn »
hfdco4 wrote:Amazing work. Did you figure out what happened to your "cats"?
yep! Saw them at the salvage yard, such an odd place to find them... left with $125 in my pocket for them (paid for the new throttle body, alternator, and a few other parts with that cash! :wink: )
The Fords:
Manny
Post by Manny »
Looks good on the rear crossmember one way to not have to worry about the cab corners. :lol: :thup:
Bullitt74
Post by Bullitt74 »
Only 17 hours? You my friend are efficient. Great work! :clap:
biggurn
Post by biggurn »
Bullitt74 wrote:Only 17 hours? You my friend are efficient. Great work! :clap:
Thanks! I have found that when it comes to projects like this, research and planning ahead save tons of time during "production" which really moves things along.
Floyd Update: Last night after work the shifter was waiting for me, seemed predestined that I should install it on the 4R75E. Lifted that cab and set to work... took some time as I had to tap a couple of the holes in the bracket (they were missed at the factory!) Then Once installed, I found that no matter how it is adjusted, it lacks throw to shift the transmission down into 1st. With the cab back on, I also found quite a bit of interference between shifter and cab floor. I went ahead and ordered the Lokar bell-crank kit to eliminate this issue. Shot an email off to Lokar tech support seeking guidance on why it will not drop into 1st. I suspect the side detent plate may be incorrect for my transmission. On the upside, I love the look, exactly what I was after, a semi-stock look that makes a person look close to see what is different. Up to 19.5 hours invested!
The Fords:
biggurn
Post by biggurn »
Finally had a day off to work on project Floyd. The crank bell kit arrived for the shifter, it shifts much easier. I'll have to see if it hits all the gears once its running. From the shifter I moved to brakes. Mounted the master cylinder and modified the brake pedal to work with it. I also routed the park brake cable, but it needs some adjustment to function properly.
With the brakes squared away, I started back into body panels. Front fenders are mounted! I'll have to pull the outer fenders off to work on getting the core support mounted next... I'm up to 25 hours invested.
The Fords:
cdnwillyg
Post by cdnwillyg »
Coming along nicely! Lots of work for sure. :thup: 8)
Stony Plain, Alberta, Canada
:drive:Willy
biggurn
Post by biggurn »
Another busy day for Project Floyd! Managed to get the core support mounted. This required some significant modification of the frame rails and the core support with a side of welding. All said and done, looks and fits well!
YoungFordKid came by this evening and we started on wiring. While he worked on the main harness, I focused on the engine and transmission harness. I'll need to order a few sensors for the engine, but that part is about done...
the chassis wiring still has a little way to go!
33 hours total invested so far into the build!
The Fords:
cdnwillyg
Post by cdnwillyg »
Good work, I like the low look it will have as well. 8) Sure not wasting anytime on this build. :thup:
:drive:Willy
