'69 overhaul- CV, 8.8, and more.
rms
Re: '69 overhaul- CV, 8.8, and more.
Post by rms »
IN2FORD wrote: Hey Ryan, you are thinking correct on the bed bolts. You cannot access them. I did not realize this till after the fact so I do not have bed bolts there. If you can weld in nuts for those you will be good to go. As far as inner fenders, I had to trim very little around the CV frontend. Probably no more than 1/2" or so. I bought one new one from DC and wish I had bought both. Had to do alot of work to get the other to look as good as the new one.
Barry
Thanks Barry, I thought your inner fenders looked new!
Anybody know the torque specs on the CV main bolts, and the nuts?
-Ryan
1969 F100
Lone Ranger
Post by Lone Ranger »
rms wrote:
Lone Ranger wrote:Wow great job. I thought it was sweet before you started but once it's done it's gonna be awesome!
Thank you! I would absolutely love to have a highboy like yours one day, it is so cool!
That's funny cause I'd love to have a truck just like yours. I'd also like a crew cab :D
Kyle
WhitsEnd
Post by WhitsEnd »
"Bought new sleeves from Ford...."
I would be very interested in elaboration on that. These tubes that are part of a welded frame are available individually?
Can you share the parts numbers? Did you just purchase from a local dealer?
Thanks.
8) 1970 F100 Ranger 2WD
rms
Post by rms »
WhitsEnd wrote:"Bought new sleeves from Ford...."
Thanks.
Yes, they are available individually. I ordered online from Tasca Ford, and they were $29 each. Part number below:
3W1Z-5D096-AA
-Ryan
1969 F100
rms
Post by rms »
Quick test fit of the front wheels to see how they look with the big brakes. I was originally going to remove the “Corvette” raised lettering on the calipers, but it’s so subtle that I’m going to run with it. Plenty of wheel to caliper clearance too.
Bolted up the rear sway that came with the Explorer 8.8. I’m going to weld some 1” threaded standoffs where the nut is in the picture. That way I won’t have to access behind the frame where the fuel tank is. Now to find some M12 standoffs.
Got me a new MC too.
-Ryan
1969 F100
Tyler68
Post by Tyler68 »
Nice build! where did you find the adapter brackets to bolt the corvette calipers to the cv spindle?
hfdco4
Post by hfdco4 »
Since you install a cv front why not go with a 4.6 or 5.4 ford? It will bolt right up and they make great power.
:fr: FE390PC
rms
Post by rms »
Tyler68 wrote:Nice build! where did you find the adapter brackets to bolt the corvette calipers to the cv spindle?
Thanks! A guy on the Mercury Maurader forum makes them and I was lucky to stumble upon the thread over there.
-Ryan
1969 F100
rms
Post by rms »
hfdco4 wrote:Since you install a cv front why not go with a 4.6 or 5.4 ford? It will bolt right up and they make great power.
I am considering all options, however the 6.0 LS is leading at the moment due to cost and power.
-Ryan
1969 F100
hfdco4
Post by hfdco4 »
Hey it's your ride, but for me it will be a ford in a ford.
:fr: FE390PC
Dollarbill
Post by Dollarbill »
Wow!!! I am doing the EXACT same thing only on a 66 F100. Im not on any of the 66 forums and as I have a 67 bump i do rob ideas from this forum. I have my frame on the lift now and just got my CV bolted in and the 8.8 sitting on the leaf springs when i noticed that i may need shims. I guess i will wait or if anybody has needed them please chime in. I had my frame blasted and just got it epoxy primed Friday. Its cool that you and I are about the same place on the build. I am also planning on a LS engine in this truck. Im wondering on how to do the engine mounts.
1967 F100
Dollarbill
Another question...
What are you doing on shocks? Are you leaving the base plate and mod’ing the upper mount?
As far as bed bolts go... i got a set from the later model ford trucks, the ones with the t50 heads. Only thing ive noticed is that my bolts are 2” and 2-1/2”. The newer bolts are way longer and the “shank” up towards the head is bigger than the square hole made in the bed for the oem bolts. I may try to run a metric die up on the threads and make them work and grind some of the shank down so they will drop in the bed holes. The factory bed clips for the late model bolts will work on the frame as the throat is deep enough for the holes. Hope that makes sense.
1967 F100
rms
Post by rms »
I haven’t made it quite yet to the ls motor mounts, but enough people have done it, so there must be something out there. I plan to use the factory Explorer shock plates with the F100 shocks. I haven’t mocked that up yet, but I’ve seen others do it that way. Good info on the bed bolts. If I can find something like that to work, great. If not, I’ll just leave those 2 out. 6 outta 8 should be just fine for what I use the truck for.
-Ryan
1969 F100
rms
Post by rms »
As for the rear shocks, I just went out to verify the Explorer shock plates line up...and they do. These shocks are from an 87-95 Jeep Wrangler. They have the same mounting holes as the F100, but are shorter for the truck being lowered.
-Ryan
1969 F100
Dollarbill
Bless you for that info! Lol
1967 F100
