Flipped my front hangers...what degree of shim???
OltxF100
Re: Flipped my front hangers...what degree of shim???
Post by OltxF100 »
OK I am looking at the djm dream beams and they are saying there is no difference between 67-72 & the 73-79. I thought the king pins were different?
Am i going to have to switch to 73+ spindles if i use dream beams?
-Keith
HIO Silver
Post by HIO Silver »
OltxF100 wrote:OK I am looking at the djm dream beams and they are saying there is no difference between 67-72 & the 73-79. I thought the king pins were different?
"They" are correct. The difference is in the spindles (and kingpins) if swapping to discs.
68-74 spindles are interchangeable and 75-79 are interchangeable and corresponding kingpins must be used for the spindle year.
If merely swapping stock I-beams for DJ beams, then the spindle doesn't matter. Just spec the kingpins applicable for your year truck. Dig?
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
